3 year long issue of of delay possibly electricity related
unclejake2223
Post by unclejake2223 » 16 Jul 2026, 23:43
I've been chasing this input lag/delay issue for a long time now, and at this point I feel like I've tried almost everything imaginable.
I've switched ISPs, tested different modems and routers, done fresh Windows installs more times than I can count, optimized BIOS settings, tested different GPUs, CPUs, RAM, SSDs, monitors, mice, keyboards, cables you name it. I even upgraded to OLED monitors and built a much higher end PC because I thought hardware might be the issue. I've spent thousands of dollars trying to isolate this problem.
Lately, I've been focusing heavily on the electrical side because it's one of the few areas left that could explain what I'm experiencing. I've done a ton of electrical troubleshooting and research, checking outlets, circuits, power quality, and trying different power setups.
One thing I found out recently completely surprised me: I always assumed my house had grounding rods, but apparently it doesn't. I never even questioned it because I figured every home had them.
So tomorrow I have an electrician coming out. They're going to install a whole-house surge protector at my breaker panel, redo the breaker panel with new breakers, clean up and reorganize all the wiring, and make sure everything is installed properly. I'm also having them check the grounding situation and get everything up to code if needed.
I'm not saying this is definitely the cause of my input lag, but after exhausting software, networking, hardware, and just about every optimization imaginable, the electrical system seems like one of the last major variables worth investigating.
I'm curious how many of you actually know whether your house has grounding rods? Is that something you've ever checked, or did you just assume they were there like I did? If you've had electrical work done to improve PC performance or reduce strange issues, I'd be interested in hearing about your experience.
ablemor
Re: 3 year long issue of of delay possibly electricity related
Post by ablemor » 17 Jul 2026, 05:20
Why don't you wait for the electrician and write the post after that? By the way, what exactly is your problem, what kind of input lag? There are so many types of it.
unclejake2223
Post by unclejake2223 » 21 Jul 2026, 02:13
yeah zero fix. GG might just give up
MontyTheAverage
Post by MontyTheAverage » 27 Jul 2026, 07:19
unclejake2223 wrote: ↑
21 Jul 2026, 02:13
So you had electrician come in? What did they do, change, or add?
Did you have them check the resistance of your ground? Check your neutral?
Lanaxi
Post by Lanaxi » 28 Jul 2026, 05:34
Hello, how do you measure neutral resistance?
My earth resistance is 15 ohms.
unexpected8
Post by unexpected8 » 28 Jul 2026, 06:31
According to my information, it should be 5 ohms or less.
I'm waiting for other replies; I might be wrong.
unclejake2223
Post by unclejake2223 » 28 Jul 2026, 20:37
MontyTheAverage wrote: ↑
27 Jul 2026, 07:19
21 Jul 2026, 02:13
we just installed two grounding rods because we didnt have any then re installed breakers because some were old , also to add on we added the cold water grounding as well where the grounding also is attached to the water tank cold pipe etc, we didnt check the resistance unfort , also the ground is hard to penetrate when using tools so im assuming it had to be 8ft in the floor and a good 15 inchs from the copper rod is still sticking out , ima check the resistance my self im sure i have tools for it and ill lyk but also ohms would have to be below 5 correct?
Abdulrahman
Post by Abdulrahman » 29 Jul 2026, 07:29
If you notice any improvement after the technician's visit, let us know what they did.
