X3D processor tip
Vocaleyes
X3D processor tip
Hey guys, if you have a *Dual CCD X3D chip, in Windows ALWAYS use the balanced power plan, not high performance.
Just in case some didn't know and turned it on by default.
cheers!
cheers!
- kyube
Re: X3D processor tip
Vocaleyes
- RealNC
All I can find is a reference to a Hardware Unboxed benchmark that compares balanced vs performance, but this video doesn't actually seem to exist? If it does, a search doesn't find it.
joseph_from_pilsen
The trick with ballanced power plan being superior is however a bit outdated today. At 9800X3D there is almost no difference at all, especially with overclock applied. There were some changes and optimalizations in AGESA and scheduler made in time between so its no more so much straigtforward "better".
Hyote
It is basic info that only dual CCD CPUs need the balanced power plan.
Vocaleyes
That's entirely my mistake. I should have specified "for dual CCD chips". For single CCDs like the 9800X3D, 7800X3D impact is minimal.
Hyote
My 9850X3D feels the exact same than my 10850K did apart from the massive performance boost.
donger
Source is AMD engineers i remember them talking about balanced power plan many many times...
