AMD KVM Mouse Protocol (Scewin)
dermodemon
Post by dermodemon » 15 Aug 2026, 10:54
So i have in my nvram.txt the setting called
Code: Select all
Default setting - Auto (simple).
Modded settings - Absolute.
I definitely feel the difference between simple and absolute. Absolute feels much more sharper
Try it out maybe it will help you a little bit.
MOBO: Asrock b450m pro4-f (10.60 bios.)
Setup Question = AMD KVM Mouse Protocol
Help String = Swtich KVM Mouse Protocol between Absolut/Simple
Token =2B // Do NOT change this line
Offset =54
Width =01
Options =*[00]Absolute // Move "*" to the desired Option
[01]Simple
[03]Auto
ablemor
Re: AMD KVM Mouse Protocol (Scewin)
Post by ablemor » 15 Aug 2026, 12:37
Isn't this a placebo? + This is only available on AM4
dermodemon
Post by dermodemon » 15 Aug 2026, 15:04
ablemor wrote: ↑
15 Aug 2026, 12:37
I am 100% confident that mouse feels different with absolute setting.
kyube
Post by kyube » 17 Aug 2026, 00:10
dermodemon wrote: ↑
15 Aug 2026, 10:54
--snip--
I suggest that you try benchmarking this using a ETW-based tool.
xtw is a easy way to evaluate this.
Ideally, test in-game instead of on desktop.
For example:
On my AM5 system (Asrock motherboard), I was able to notice a decent reduction in DPC usage by disablng XHCI Hand-Off in UEFI. YMMV.
