Monitor - Acer VG240ys, 1080p 165hz
Warranty - 1 monitor panel replacement by Acer a year ago, warranty is expired now.
Issue - Rows of pixels at the bottom of the panel show defects. (Please check the attached images)
I know this is not a gpu problem as i have tested with other displays which has not reproduced this issue. I have also came across a reddit post of the same problem I am facing the title of the reddit post is "Horizontal line of pixels that don't display the proper color"
What is causing this problem, is there any way to repair it ?
Thank you
Horizontal pixel defect in monitor panel
zippy19k
- IMG_20260912_132936.jpg (1.45 MiB) Viewed 221 times
- IMG_20260912_132956.jpg (1.58 MiB) Viewed 221 times
- IMG_20260912_133010.jpg (1.34 MiB) Viewed 221 times
