Sygey3 wrote: ↑Today, 07:36
Is Clear CMOS required with every Windows installation?
Am I correct in understanding that before installing Windows, I need to go into the BIOS and select Secure boot — Disabled, while setting Secure boot mode to Standard? After installing Windows, I need to go into the BIOS and select Secure boot — Enabled and Secure boot mode — Custom, and reset the keys to factory defaults?
Is it better to install Windows with a Microsoft account or without? Should I enable or disable the internet during installation?
Resetting the CMOS before installing Windows is mandatory.
To start with, before installing Windows, try enabling Secure Boot and Custom mode, and reset the keys to default.
When you are at the Windows setup stage and are asked to connect to the Internet, press Shift+F10 and enter the command `start ms-cxh:localonly` to create a local account.
After installing Windows, fully update the system, and then install the drivers for the motherboard and GPU.
Alternatively, do exactly the same thing but with Secure Boot disabled, and let me know if you noticed a difference and how significant it was.
