hitreg issue/constant tps/heavy desync/animation skips
Posted: 26 Sep 2026, 04:52
Its been 4 years since it happened for the first time.
I was into many FPS games like valorant/cs2/warface and my game experience was not what i expected
I changed every pc part i could but nothing changed. also i was switching to others platforms like am4-am5-lga1200
Tried 10~ different ISP and i moved to other locations 9 times i noticed that this trouble happens over time just by using my pc
Initially everything is fine but then after couple of days sometimes even longer the problems starts to appear
The first problem is terrible hitreg
sometimes when i shoot the enemy my bullet can just go through them and it can happened around 10 times per game or even the bullet was not registered on the server.
here's the example: https://youtu.be/KePQdIg8zP4
the second problem is teleports when being shoot
when enemy shoots me in the body my character can tp backwards and my screen is tearing and crosshair goes in whatever direction
(it can be described as desync ig)
here's the second example: https://youtu.be/0ORTuHTRJvM
the third problem with animation skips
the enemies legs are not moving properly (always) to add a bit of absurd even bots in the range are moving strangely
for an example everyone can wide-peek me on full speed and instantly stop in 1 frame or they can just do a simple strafes and it will seem like he moves all the time (its not about peek advantage, ping diff or some type shit)
here's the link: https://youtu.be/GaegFh3LZ3E
i hope someone knows about this problem and could help me a little.
