Just hit 340Hz!
rabidz7
Just hit 340Hz!
Post by rabidz7 » 22 Nov 2014, 21:16
The yokes gave out around 350Hz (the monitor is fine when refresh rate is lowered; no CRTs were harmed), with the image bouncing up and down the screen, but 340Hz is still absolutely incredible. Imagine what modern CRTs could do!Image
EDIT: 344Hz also works fine.
Rabidz7 is a: PowerPC Fan, LCD and x86 Hater, and a Plasma/OLED/CRT/SED/FED Lover
Re: Just hit 340Hz!
Post by Chief Blur Buster » 22 Nov 2014, 22:34
Sweetness!
(which web browser is that?)
Now you want the GPU silicon to push 340 frames per second through that! Or run some older games.
rabidz7
Re: Just hit 340Hz!
Post by rabidz7 » 22 Nov 2014, 23:50
Chief Blur Buster wrote:Sweetness!
That's Chrome. Unfortunately, I had to drop to 240p to do the 340Hz. It was more of a test to see how fast a good CRT could go and to see what extreme refresh rates felt like than an attempt to get a usable resolution. I play at 1600x1200@100Hz in almost everything or 800x600@200Hz in a few FPS games, so I have a Classified 980 on the way.
Re: Just hit 340Hz!
Post by RealNC » 23 Nov 2014, 06:59
"They don't make them like that anymore."
More relevant than ever, heh.
Black Octagon
Re: Just hit 340Hz!
Post by Black Octagon » 23 Nov 2014, 13:04
What screen was this with (sorry if that should be obvious...am on Tapatalk)
Re: Just hit 340Hz!
Post by Chief Blur Buster » 23 Nov 2014, 15:51
Black Octagon wrote:What screen was this with (sorry if that should be obvious...am on Tapatalk)
CRT computer monitor with a very high scanrate capability.
Haste
Re: Just hit 340Hz!
Post by Haste » 23 Nov 2014, 16:08
Awesome!
Monitor: Gigabyte M27Q X
flood
Re: Just hit 340Hz!
Post by flood » 25 Nov 2014, 01:40
he has a nokia pro 445
LagBuster
Re: Just hit 340Hz!
Post by LagBuster » 27 Nov 2014, 03:48
Interesting. I thought that the maximum refresh rate that CRT's were capable of was 200Hz. :shock:
I assume you have to bypass the monitor's 'out of range' protection in order to do this? If so, how exactly do you do that? I might be interested in testing higher than 170Hz on my CRT.
Also, doing this can cause permanent damage to the gun, right?
flood
Re: Just hit 340Hz!
Post by flood » 28 Nov 2014, 03:11
from my understanding
the gun isnt affected by high frequencies at all, especially as the pixel clock is low at these resolutions. its mostly the yoke and flyback transformer that are strained by these rates
his monitor apparently has no refresh rate limitation but he says the yokes start to malfunction at 350hz
