Antenna cable causes weird interferences, floating mouse, weird monitor and ferrari peeks?
Posted: 12 Nov 2026, 19:43
by kordyyyy
Hi everyone, I've been having problems with interference, I think EMI and RFI, for years. 8 years ago I lived elsewhere and I used to fly on aim trainers. I moved here and on Valorant, even though I have good aim, enemies ferrari peek me, the mouse is floaty and uncontrollable, the monitor doesn't display smoothly and it looks more like 120 than 240Hz. Hitreg and recoil are very bad, even with the crosshairs on the head, etc. These days I decided to look around the house and I noticed this TV antenna cable. It should be an RG6 coaxial cable, which, as you can see in the photo, goes through the walls from the living room to my bedroom and goes all the way around the room to my parents' bedroom, where they also have a decoder. Today I noticed that by moving my desk with my PC and monitor a little further away from the antenna cable that runs along the floor, my monitor is clearer and my mouse works better, too. But my enemies still pick on me most of the time, and as before, I often see them running and shooting me in the head from 40 meters away without me being able to react. But the situation has improved slightly. Tomorrow I'd like to try placing my PC near my bedroom door, away from the cable, and see if that helps more. I'm also worried because that cable runs just 2 cm below the fiber optic box where the modem is connected, and I might lose packets. Can I cover something with aluminum foil or use ferrite clips? What should I do? I'm sorry, but I don't know much about this. If you have any problems like this, try to see if any cables are causing problems <3
Re: Antenna cable causes weird interferences, floating mouse, weird monitor and ferrari peeks?
Posted: 15 Nov 2026, 09:14
by Asesino34
I'll reply because I've already tried that. I removed all the coaxial cable from my house since nobody was using it, but nothing changed. However, I still have the antenna, and I've always had it. Maybe I should remove it and see if that makes any difference. But there are a lot of people here who, I ASSUME, live in houses without that kind of antenna and still have the same problem.
