DSC eating display "heads" - where can I find more info?
Posted: 17 Nov 2026, 13:49
by ZeroPaladn
Title. I've been searching around for a bit and can't seem to find proper sources or testing for this! What I've found so far:
40-series and older Nvidia cards use two "heads" per DSC-enabled panel, limiting you to 2 DSC'd panels on consumer cards or 1 DSC'd panel with two more without. 50-series cards have no data, or even claims, floating around for this. The only real source I can find for this is Nvidia's help doc about it that's almost 3 years old and predates the 50-series cards.
Consumer AMD GPUs from the 7000 and 9000-series reportedly never suffered from this problem, but AMD has literally no documentation for it and I can't find any testing.
Don't suppose you guys have any reliable testing data or sources hidden somewhere?
Re: DSC eating display "heads" - where can I find more info?
Posted: 20 Nov 2026, 02:46
by Dalek
What exactly are you trying to achieve? No DSC?
Posted: 20 Nov 2026, 02:53
by RealNC
ZeroPaladn wrote: ↑
17 Nov 2026, 13:49
My 4070 Ti S only uses one head for DSC on a 10-bit color, 240Hz 1440p monitor. A second head would only be used if it were 4K, or higher refresh than 240. 360Hz+ 1440p monitors for example need two heads. Or probably if it was a 12-bit panel instead of 10-bit, although not sure on that one.
Posted: 22 Nov 2026, 07:17
by kyube
ZeroPaladn wrote: ↑
17 Nov 2026, 13:49
The only "source" we have is GGoki's claim of Blackwell having a 1620MHz pixel clock, as per a Nvidia resource.
This implies that, even on Blackwell, we have a limited display engine.
As soon as one hits a pixel clock (misleading label by Nvidia) of 1620MHz, which is somewhere between HDMI 2.1 FRL5 & HDMI 2.1 FRL6, you require 2 heads to be fused.
This means software features are going to get limited to some extent.
You can test out if there's any AMD software feature which breaks by relying on CRU, AMD's control panel and GPU-Z (if DisplayPort)
Of course, these are all limited in rigor. There's hardware which can measure the exact bandwidth a display is doing and whether any compression is going on.
They are out of reach in terms of budget for most buyers though... :D
