benq xl2411z overclock
Posted: 24 Nov 2014, 12:49
Hi. Im gonna to overclock my xl2411z screen. In other forum i've got a reply :
"1024x768 doesn't matter, they are all downsampled 1920x1080 resolutions anyway.
144hz isn't even directly supported at normal timings. 144 hz requires reduced timings, so 150hz: no way. 144hz won't work with standard timings. Highest possible with standard timings is ~128-130, afaik.
Someone managed 146 hz with reduced timings.
If you're trying to get less motion blur, you should be using blur reduction anyway."
Ok, then i gonna overclock to 129 hz at nvidia control panel.
When i do 1024x768 @ 129hz in OSD i've got "1024x768 @ 120hz" @ std timings. (I creating resolution in nvidia control panel).
But when i create 1024x768 @ 129hz at CVT REDUCED BLANK, in OSD i've got "1024x768 @ 100hz"
This is OSD bug or that overclock don't work?
Waiting for reply guys !
