Audiophile equipment for heavy mouse
Posted: 20 Nov 2026, 18:04
Trying to battle with EMI issues, I figured eventually that every electronic device or component, including your own gpu produces noise. What drastically improved my issue is audiophile-grade equipment and proper device topology (what connects to what).
What I recommend for anyone experiencing these issues, first buy 5 to 6 of these from Aliexpress
https://www.aliexpress.us/item/32568088 ... pt=glo2usa
They are cheap, place them on motherboard and monitor usb empty ports, connect nothing on the other end (buy the male to female option).
If they noticeably improve heavy mouse then device interference is the cause. Going down the path of fully mitigating the issue may demand more expensive options. The devices and benefits they offer can stack with each other, including using multiple of the same device. Examples that i currently use are:
USB OPTIONS:
Jitterbug: connect nothing to the other end
iSilencer: place in usb ports you USE and connect your devices (keyboard, mouse etc)
same as iSilencer but for isolation: in series with your devices
POWER:
Proper power strip
parallel noise filtering: place in empty sockets of your power strip
Display:
PURE FIBER CONNECTION paired with fiber
HDMI FILTER
Ethernet:
PURE FIBER CONNECTION (again ruipro) paired with fiber
Ethernet FILTER
USB OPTIONS:
POWER:
Proper power strip
Display:
HDMI FILTER
Ethernet:
Ethernet FILTER
