Help me BlurBusters, you're my only hope.
R1chMahogany
Post by R1chMahogany » 22 Nov 2026, 13:39
I play games on one monitor and have stuff going on my TV as a second monitor. They're both 120hz VRR g sync compatible. What I'm noticing is that if I'm playing a game with g-sync on, the TV has the fps drop when its window becomes non-active, which causes lots of stuttering and whatnot when watching streams. I can see this when I run the UFO test too. It cuts from 120hz down to about half. Is there any way to fix this? I've tried using hdmi vs displayport, DSC vs no DSC, no HDR, 60hz instead of 120 hz on both screens, fullscreen vs. borderless fullscreen vis windowed, fullscreen optimizations, no gpu scheduling, Driver re-installed, windowed vs non windowed, borderless vs exclusive, scaling changed, making the TV the primary with the game and the monitor the secondary. Nothing makes a difference.
If i set the game not to use g-sync in the control panel, it's fine. If I turn off g-sync globally, it's fine. I even tried turning off VRR on my TV, and if i pull up the UFO test on the TV while I launch a game with gsync, it starts chugging. It doesn't appear to be matching the FPS of the primary monitor either, even if the game im playing is running over 120fps, the non-active windows get their FPS cut in half. If I click back to making the other screen active, the fps shoots up on the ufo test or video im watching, even if the game is still being rendered on the other screen. It's just the act of making it the active window that's the difference. The UFO test has the 120 hz on the top bar, 60 in the middle, 30 at the bottom. When this happens it's almost like each one gets halved almost exactly but not quite sometimes.
Conversely, I also notice that when I switch the active window to the non-game monitor, the game FPS I can see in the overlay almost gets cut in half too. I also noticed in the ufotest when it starts happening, it says "waiting for sync" and then eventually "sync failure, close tabs and programs, fps too low." I check the resource monitor and my resources are not maxed out at all. Sometimes I'll boot up CS2 to test....and it holds steady, then if i go into the settings and increase the max fps in CS by just 1, the ufotest goes crazy and starts saying sync issues. Sometimes in some games it seems like the ufotest fps is exactly what the game fps is and changes with it like they're in sync, other times it just goes to 60/30/15.
I also noticed that the only time it doesn't happen is if I'm playing a game that is extremely lightweight like slay the spire. But if i drag the window around then the problem starts happening. I can see as the window is being dragged the g-sync indicator goes off, slay the spire FPS drops to 60, then when you stop moving it comes back and the framerate goes back up. Another thing i noticed is if the game is running in the active window and shows g-sync indicator in the corner, if I switch to the other monitor, the g-sync indicator turns off. It seems like if the frame rate is steady (like in a lightweight game) at 120, it can manage. But if you do anything to make that framerate fluctuate like move the window, or change the in-game fps max, it sets it off. But it doesn't recover. It's not like it takes a second and then stabilizes again.
I also ran another steam game on the other monitor so i could see the fps of the screen while i had another game running on my primary monitor...it stayed steady. I tested edge and brave and firefox all the same thing. I also pulled up the video stats while watching a 60fps twitch stream, and I can see when I switch back to the game the skipped frames starts going up quickly. Switch back to the stream and it doesn't skip any. Then I put a 60fps video on mpv for local playback, same thing it starts dropping output frames like crazy.
Another thing I noticed, I pull up Slay the spire which has a 120hz cap, the game comes up and the dropped frames on twitch mostly stay fine, then if i go into the settings and drop the max frame rate down, the dropped frames on twitch start spiking non-stop, even if i click back on the twitch video and go back to the game. But, if I change the game fps max back up to 120 - the dropped frames stop on twitch. I literally have it so that I can make my twitch stream start stuttering and fix it by clicking the left and right arrow in slay the spire fps limit. It does seem to be related to whats on the primary monitor, specifically when it comes to instabilty. If I load up rocket league and set it to 60fps, ufotest goes to 60 and holds steady. If I set it to 120, UFOtest goes to 120 and holds steady. But if I set it to 75 or uncapped, ufotest starts going nuts.
ANOTHER thing I tested, to see if the windows lose fps if they are on the same screen as the game being run in windowed with g-sync -- yes they do. So it's active window specific and not screen specific.
The thing I noticed that I think is really telling is that even if I turn both monitors to 60hz, the same thing happens. So now on ufotest the 60hz band gets cut to 30, the 30 to 15, and the 15 to 8. So it's not a performance issue it's clearly either a known issue or a bug happening. It would be good if someone else could test thing if they have a similar setup.
Win 11 Pro
9800x3d
rtx3070
32GB ddr5
nvme ssd
monitor 1: msi mpg 321urx with gsync on fullscreen, hdr on, 4k 120hz using hdmi 2.1
monitor 2: samsung qn90b with gsync on fullscreen, hdr on, 4k 120hz using hdmi 2.1
