XG2431-Issue
Posted: 25 Nov 2026, 17:07
by qvik18
Hello, looking for some help with my ViewSonic XG2431 (24-04 batch).
Gaming at 240Hz or 144Hz or any other resolution feels super jittery and unsmooth. Even with high FPS, it honestly feels like I’m playing on 60Hz—movement and aiming feel heavy, and spraying in-game feels laggy and totally out of sync.
One weird thing I noticed in CRU: the detailed resolution only shows 1920x1080 @ 60Hz, and there’s no DisplayPort block at all—just an HDMI block which has 1920x1080@239hz,1920x1080@144hz and 1280x960@60hz.
Right now, the only way I can get the game to feel little bit smooth and have my spray actually synced up to an extent is by adding a custom resolution (1280x960 @ 240Hz) in the CTA-861 block and also use SRE for GPU resolution, and then setting NVCP to GPU scaling with "No scaling." When I do this, the desktop shrinks to a square size window with horizontal and vertical black bars(reso in settings 1280x960@240hz) though monitor Osd reads 1920x1080@144hz .(there are 2 resolutions along side my custom resolution in ct block,1920x1080 @144hz and 1920x1080@240hz)
Here is what I’ve already tried with no luck:
VESA-certified DP cable
G-Sync + V-Sync + Reflex
CRU display scaling method
Clean Windows reinstall
Online UPS with a 1:1 isolation transformer
Any help is appreciated.
