Acer XB280HK fails after 5-10 min g-sync. Overheat?
dfitterer
Just got an Acer XB280HK and love it. Except, when used in g-sync mode, the monitor fails after 5-10 minutes of gaming. The displayed image freezes and fades to white over the course of about 1 second. It stays full white even if the displayport cable is unplugged and replugged or the front power button is used to turn it off and then on. The only fix I've found is to unplug the monitor's power or use the monitor's power switch in the rear to toggle it on and off (which games don't tend to handle well).
Anyway, does that sound familiar to anyone? I've tried multiple DP 1.2 cables and multiple ports on the geforce 980. Hoping to hear about a software solution before sending it back to newegg.
- RealNC
Re: Acer XB280HK fails after 5-10 min g-sync. Overheat?
No, that sounds like a defective unit, especially if you use the cable that comes with it.
Alamar
Btw this monitor, is there working 1080p (no interpolation) resolution with gsync or only 2160p with gsync? (probably like in others [rog swift] only one resolution can work with gsync with is I think a significant minus of this tech..).
dfitterer
I ran a game in 1080p and the monitor reported being in 3840x2160 g-sync mode. Not sure exactly what you mean about interpolation - the game wasn't surrounded by a black frame and did fill the entire monitor.
Interestingly, the monitor didn't fail under those conditions. That was likely because g-sync reverted to v-sync because of a high framerate though.
- RealNC
There are no LCD monitors without interpolation when using non-native resolutions. G-Sync or not, doesn't matter. Only CRTs do without interpolation.Alamar wrote:Btw this monitor, is there working 1080p (no interpolation) resolution with gsync or only 2160p with gsync? (probably like in others [rog swift] only one resolution can work with gsync with is I think a significant minus of this tech..).
bfedorov11
So when you turn the monitor back on the game is still there working?
If not.. I am willing to bet its your video card overheating. Most likely you weren't stressing out the card enough on 1080. You should be able to turn your monitor off and on while gaming with no problems.
If you want to test in 1080, you have to set it to 1080 in the game's settings, not windows.
Falkentyne
He said that using the front power button--what we're talking about here, doesn't fix the corruption on his monitor. He has to actually -unplug- the mains (cut AC power), which pressing the power button does not do.
The reason games don't 'handle' that very well is it's like HDMI hotplug...it probably has hotplug in displayport also, so when the screen is disconnected/ac off, it acts like a hardware device is removed, so games can lose focus and freeze since theres no longer an active display information.
Comodin
Was it a defective unit or what was the cause of this?
I am wondering because I have the exact same issue with my XB280HK but sometimes it happens after 10 minutes and sometimes after several hours.
Danybonin
Not true. I can play with gsync activated in 1080 with my rog swift.Alamar wrote:Btw this monitor, is there working 1080p (no interpolation) resolution with gsync or only 2160p with gsync? (probably like in others [rog swift] only one resolution can work with gsync with is I think a significant minus of this tech..).
5930k at 4.4 Ghz
Asus x99 deluxe
16GB ddr4 3000mhz
2080 ti
ssd 850 pro 512GB + 1T evo 840 + 1T pcie ssd
win 10 64bits
Asus pg27uq 4k HDR 144hz monitor
(sorry for my poor english, i speak french)
Asus x99 deluxe
16GB ddr4 3000mhz
2080 ti
win 10 64bits
Martijnluka
EXACTLY the same here ! any solutions yet ?Comodin wrote:Was it a defective unit or what was the cause of this?
