Profiling strobed display.
boniek
Post by boniek » 12 Jan 2014, 05:08
I have heard that not every profiling device can be used with every display and backlight type if you want best (accurate) results. Is i1 display pro sufficient for profiling strobed displays?
i7 3770
16 GB RAM
GTX 670 2GB
ROG SWIFT PG278Q
Re: Profiling strobed display.
Post by Chief Blur Buster » 13 Jan 2014, 01:08
Yes, i1 Display Pro is able to work with strobed displays -- The i1 devices also work with projectors / plasma / CRTs, so are relatively flexible.
