I've read your very good article, and see there are a few choices
XL2411Z, XL2420Z, XL2720Z, XL2420G
The last one seems most expensive, but do they all give the same quality of blur reduction when playing 60hz console games using the utility?
Best z series monitor for console?
Falkentyne
Re: Best z series monitor for console?
They are all fine for consoles. You can use 60 hz single strobe (you can set single strobe on in the service menu).
The 2420G is a gsync+classic dual module in one monitor (G sync module+z series module).
On 2420G, you would use classic mode and HDMI for blur reduction on consoles.
