Install Help [G-SYNC Upgrade Kit]
I'm on the final step where you plug in the long white thin cable with the blue tip. The video says that the connector on the board has a little flap that opens up, and you're supposed to put the tip in there then press down.
Mine is either missing the flap, or it's incredibly hard to open. Ideas?
Re: Install Help [G-SYNC Upgrade Kit]
Can you please post a close-up photograph?PiERiT wrote:I'm on the final step where you plug in the long white thin cable with the blue tip. The video says that the connector on the board has a little flap that opens up, and you're supposed to put the tip in there then press down.
Or a link to one of the photographs or specific YouTub
This will help me assist you.
Do you mean this point 13min30sec into the video?
Does your connector look similar to this?
Be extremely careful, that connector is fragile. If you are stuck, take a photograph of the connector and post it. If you can't reach it with your finger, you may need to very gingerly, gently, carefully use your plastic pry tool to lightly click it upwards. Do not force it, however!
Note: Blur Busters dislcaims all responsibility for damage to your monitor. Proceed at own risk. That said, this forum welcomes feedback!
That's the one. I figured it out, though.
I had to pull it outwards before it would raise up. It's hard to describe. Basically, after the guy in the tutorial presses it down, you can also push it backwards, and it snugly pushes in. Mine was in that pushed in state from the get-go. I guess most peoples' aren't?
Aha, yes, the lock mechanism!PiERiT wrote:That's the one. I figured it out, though.
As you noticed, the lock mechanism is designed to lock down the ribbon cable so it stays put.
Ideally, you want to undo the lock mechanism before pulling the flat ribbon cable out; so usually the lock mechanism is disengaged when you reinstall the flat ribbon cable. But that's not what you experienced -- you had a locked empty ribbon socket, and got stumped at this step.
Good to know, so we can inform other users what to do, if they are stumped by this step.
Well, on the stock board, it just lifted up. I didn't have to unlock anything. So when it was locked on the GSYNC board, it took a while to figure out.
Everything is up and running now. I'm mildly worried about one thing, though. Ya know in some games when you change a setting, the whole screen goes black for a split second, like the input is lost? That's how mine works with GSYNC off, but with it on, some of the screen is black and the rest of it is like a rainbow. Is that normal?
I've never heard of this. Can you take a photograph?PiERiT wrote:Well, on the stock board, it just lifted up. I didn't have to unlock anything. So when it was locked on the GSYNC board, it took a while to figure out.
If it is what I am thinking, maybe a ribbon cable is loose and simply needs re-seating (jiggling).
But post a photograph, so I can confirm.
I'll try to get a picture. It's only present for a split second, so I might not be able to.
You are referring to the ribbon cable I started the thread for? I made a special effort to get it as snug as possible, since it took me so damn long to get it installed. Plus, I assume the ribbon is used without GSYNC, since it was already present in the monitor.
Video.PiERiT wrote:I'll try to get a picture. It's only present for a split second, so I might not be able to.
Record high-def video from a close distance (e.g. camera sitting on micro-tripod right in front of you) a tripod and play continuously.
Once you're done, find the video frame and take a screenshot.
Rainbow Artifact during changing settings
Here's a couple pictures of the rainbow thing. Everything is perfect during gameplay; it's just when the input is lost momentarily when changing certain settings.
That seems to look like it _might_ be a sort of a defect -- I would currently suspect a loose connector. Try unplugging and reseating the connector (very carefully). However, if it's not interfering with your normal gameplay, you don't have to rush to open things up if the problem only shows up during mode-switching (e.g. launching a game, versus exiting a game). If this happens in the middle of a game, it may be a problem.
I will send a link to NVIDIA to this thread, to ask about the best remedy for this.
