What can I infer from these results?
Posted: 03 Apr 2015, 18:53
by YukonTrooper
I recently received the Acer XB270H monitor and I wanted to compare the input lag to an ASUS VG278HE. I used the stopwatch method in clone mode and I'm using Windows 8.1. I came up with some interesting results, and I'm wondering what, if anything, can be read into them.
- Using the web stopwatch, the clone source is 16ms slower than the cloned display
- Using the .exe stopwatch in full screen mode, the clone source is 10ms slower than the cloned display
- Which display is the clone source and which display is the clone does not affect results
Am I right in assuming the input lag is comparable between the two displays? I'm assuming v-sync behavior is being observed with the web app. It's interesting that the clone source becomes the slower display.
Re: What can I infer from these results?
Posted: 05 Apr 2015, 00:13
by flood
stopwatch methods are pretty inaccurate for computer displays.
i'd just trust reviews from prad or tftcentral. iirc xb270hu has basically no input lag and vg2478he has a few ms
they should both be fine.
Posted: 05 Apr 2015, 19:40
by YukonTrooper
Yes, the stopwatch methods are inaccurate, but I thought there might be enough data there to come to some general conclusion.
It's the 1080p 27" TN XB270H, not the XB270HU.
Posted: 05 Apr 2015, 20:20
by flood
well it depends on what you're looking for, but yes it can be used to determine if a monitor has less lag than the other if you take several pictures and swap the source/clone configuration for the monitors and always see a consistent result.
