iMac & G-Sync Monitor (external/2nd Display)
Posted: 27 Apr 2015, 03:29
Hi Everyone
I'm using an iMac as main-system and planning to add another "Gaming-Rig", as the Mac is really no gaming machine is not being able to play GTA V properly does hurt :]
I'd like to get an Acer Predator XB270HUbprz, 27" with G-Sync but I found out that G-Sync does limit the Ports to one display-port only.
I'd really like to use the Acer as secondary display, when the gaming-rig is turned off for working, but I can't find a proper way to put a display on it, without re-plugging every time.... is there a proper way with some kind of adapters/cables/switches/bridges/younameit to get the Acer working as Gaming-Rig display AND as 2nd display for the iMac (Thunderbold / Mini-Displayport) without replugging every time?
I found this, but it caps at 60 Hz (http://www.siig.com/it-products/kvms/sw ... witch.html)
So the goal is to use the G-Sync display with 144Hz @ Windows and 60Hz/1440p at secondary display for the iMac
PS: At first I've checked if I can get the gaming-Rig to use the iMac display as 2nd screen... but now way... this doesn't work with my 2010 iMac
if you have any tips, I'd appreciate it
thanks in advance
TOM
thanks in advance
TOM
