SS4 wrote:I wonder if any would make a good TV since 34-35 inches is starting to get too big for a monitor you sit only a feet or two away from lol
I use a 46" TV as my "monitor" and I wouldn't mind something larger.
50-55" would be about the limit without having to sit further from the desk.
In addition, height is generally a better indicator for perceived size than diagonal.
So a 34" ultrawide panel is not perceived to be that much larger than a 27" 16:9 panel or a 25" 16:10.
lexlazootin wrote:Bigger isn't better if you are trying to sit at your desk trying to work or game. Also, does anyway know the input lag of projectors?
I've heard that some of the newer DLPs out there are reasonable for input lag (<30ms like the better televisions) but you probably won't find something on-par with the best gaming monitors.
However most projectors are not great for motion.
LCD/SXRD have slow smeary motion with full persistence.
DLP has really fast pixels but dither noise and color separation issues.
They're hot, loud, and require you to be in a dark room for a decent image too.
Now all of that doesn't mean that projectors are bad, and if you can tolerate the color separation (rainbows) with DLP, they are pretty nice gaming displays.
But there are a lot of potential issues.
I actually had the most enjoyment out of an inexpensive Toshiba DLP years ago because it was a huge image, quite responsive, and a fair price. (something in the region of $400-500 at the time)
Once I started to move into high-end home theater projectors and spending about $10,000 on a high-end Sony SXRD, a proper screen, and full room treatments, honestly the fun just wasn't there.
When you start spending that kind of money, you really start picking apart the sharpness of the image (SXRD/LCD is very soft compared to DLP) the contrast ratio, motion handling, latency etc.
If you're going for a projector, I'd recommend something cheap and fun.
Maybe not a pico projector, as those tend to be quite dull, but a lower-end DLP with a proper lamp and 2000+ lumen output.
If you have a smooth enough white wall, I'm not sure that I'd even suggest getting a screen.
Once you start projecting onto a screen, the difference between "black" from the projector and the black velvet surround stands out.
When you're projecting onto a wall, or a frameless screen, you don't notice that.
