It's now possible to disable vsync when reaching monitor cap
Post by RealNC » 18 May 2015, 11:31
Just saw this today in the latest Linux driver release (2015.5.18, 352.09 beta):
Added support for G-SYNC with sync-to-vblank disabled. This allows applications to use G-SYNC to eliminate tearing for frame rates below the monitor's maximum refresh rate but allow tearing above the maximum refresh rate in order to minimize latency.
When G-SYNC is active and sync-to-vblank is enabled, the frame rate is limited to the monitor's maximum refresh rate.
So it's now possible to avoid input-lag when the frame rate reaches the monitor's maximum refresh rate by allowing tearing. This sounds like a good idea, since if you reach 144FPS, tearing would not be very noticeable to begin with.
Was this already supported in Windows? I don't remember this one. If not, I would assume that function will reach Windows users in the next driver release.
flood
Re: It's now possible to disable vsync when reaching monitor
Post by flood » 18 May 2015, 23:45
yup, as far as latency is concerned, this is pretty much the ideal way to handle things
lexlazootin
Post by lexlazootin » 19 May 2015, 00:41
For me running windows 8.1 and the latest nvidia drivers, it's impossible to get over 144fps because the nvidia drivers will cap it for me when Gsync is enabled.
Edit: I also feel like this transition would be VERY jarring to watch. Not only does Gsync eliminate tearing it also makes you feel like you are getting a much higher fps then you actually are. So it might feel like you are getting ~140hz then suddenly reaching the cap you are getting ~90hz plus tearing.
Might be better if someone just writes a linux program to cap fps :)
sharknice
Post by sharknice » 19 May 2015, 15:36
So did they fix the GSYNC always on thing too? I've been avoiding upgrading because of that.
lexlazootin
Post by lexlazootin » 20 May 2015, 01:05
sharknice wrote:So did they fix the GSYNC always on thing too? I've been avoiding upgrading because of that.
On windows or linux? in windows there is a tick box that disables it just fine.
sharknice
Post by sharknice » 20 May 2015, 02:48
Windows. I don't want to have to uncheck it to turn it off on the desktop.
lexlazootin
Post by lexlazootin » 20 May 2015, 03:28
Ok, I'm really curious, why don't you want Gsync on the desktop?
dmbr
Post by dmbr » 21 May 2015, 01:36
So wait, is this option available to Windows, too?
Post by RealNC » 21 May 2015, 13:06
I don't think g-sync works on the desktop, actually. It only works with exclusive fullscreen applications.
Post by RealNC » 21 May 2015, 13:07
dmbr wrote:So wait, is this option available to Windows, too?
He was talking about disabling g-sync altogether. I don't think disabling v-sync when reaching the cap works yet on Windows.
