My question is: Are there any relevant Windows-Tweaks to make a better gaming expierence?
Is MarkC's Mouse Acceleration Fix Windows 8.1 good? (For CSGO I dont need it anyway I think, cause of Raw Input, but for other games)
Are there any other good tweaks you would recoomend? Maybe any network settings to change?
Sorry for this "simple" question, but you can read sooo much different things on the internet. But I think the forums has really good knowledge.
(Windows 8.1, BenQ XL2411Z, NVIDIA GTX 970, Counter-Strike Global Offensive)
Are there any relevant Windows Tweaks?
flood
Re: Are there any relevant Windows Tweaks?
accel fix isn't need for modern games. usually it's really really obvious if there is accel
turn off power saving stuff in windows and bios
don't believe everything on the internet
Sparky
Not really any windows tweaks. The main thing for minimizing input lag is either play with v-sync off, or use a variable refresh rate monitor with a capped framerate. Network settings are somewhat game dependent. Most of the time it's just a matter of using an ethernet cable instead of wireless (especially if you live in an apartment complex or condo), and forwarding any ports the game needs to your machine(make sure the machine you game on always gets the same IP address from the router).
Bishi
Close all programs you don't need, close all services you don't need.
If you like you can try using Process Lasso for its gaming mode feature that throttles background processes so they don't 'steal' CPU while you play.
Power -> High performance.
