Benq xl2420G Gsync | Turns on Vsync
Posted: 02 Jul 2015, 02:17
by JMH
So i got my system going and i enable Gsync it enables Vsync what the hell ?
I fire up csgo with gsync turned off but Vsyn off it still feels great
So is Gsync actually working ? Sure as hell feels like it is
Re: Benq xl2420G Gsync | Turns on Vsync
Posted: 02 Jul 2015, 02:22
by lexlazootin
Gsync requires the frame rate to be lower then the maximum refreshrate of the monitor. are you saying that the frame rate is capped under 144hz when you have Gsync on? because that's suppose to happen.
Posted: 02 Jul 2015, 02:36
by JMH
Yes its capped at my monitors refresh rate but i have just seen a post Nvidia allows for Gsync plus no vsync now, and Gsync will still work
http://forums.blurbusters.com/viewtopic.php?f=5&t=2213
Posted: 02 Jul 2015, 06:12
by lexlazootin
Gsync will work if your fps is lower then your refresh rate. that setting just allows for your fps to go out of the Gsync range and just display normally. (Don't use it and cap your fps below 144~)
Posted: 02 Jul 2015, 13:13
by dmbr
What about capping fps AND turning vsync off?
Posted: 02 Jul 2015, 17:10
by JMH
lexlazootin wrote:Gsync will work if your fps is lower then your refresh rate. that setting just allows for your fps to go out of the Gsync range and just display normally. (Don't use it and cap your fps below 144~)
Well even with Gsync on and Vsync of on CSGO it still butter smoother but you don't get that feel of input lag
So ill just leave it like that, Because using classic mode i see what appears to be inverse ghosting a "WHITE BLUR" off some player models when turning left and right with AMA on HIGH but with using the Gsync part of the monitor i don't see it also has better color
aswell
