I've just installed the G-Sync DIY kit according to the instructions, however, it doesn't work. The screen shows a 'No Input Detected' message in a red-bordered box. I can access the G-Sync's OSD, and the brightness controls work fine, though.
I can't figure out what's wrong -- any ideas? (Yes, of course it's plugged in and the PC is turned on.)
[fixed] No input after installing G-Sync kit
Zr40
Re: No input after installing G-Sync kit
...as it turns out, the DisplayPort cable wasn't fully inserted into the monitor, even though it 'clicked' when I plugged it in. It's working now that I've re-inserted the cable.
Re: [fixed] No input after installing G-Sync kit
Excellent -- glad it was as simple as reconnecting the DisplayPort cable!Zr40 wrote:...as it turns out, the DisplayPort cable wasn't fully inserted into the monitor, even though it 'clicked' when I plugged it in. It's working now that I've re-inserted the cable.
