Where do I change the refresh rate?
I have been using the strobelight app for a while now, but there was a large gap of time between when i started and now. It used to be that i could go into my hidden icons area, right click and choose from a drop down list what refresh rate i wanted (120hz, 110hz, or 100hz). After having installed the new app and refresh rates, it seems the only options i have are to turn strobing on or off. Where can i switch the different refresh rates?
- masterotaku
Re: Where do I change the refresh rate?
That's something you do in the operating system. You can do it with the Nvidia Control Panel, AMD Catalyst Control Center and the monitor settings in Windows.
Monitor: Asus PG278QR
