Benq XL2430T - I must be stupid.
Posted: 29 Aug 2015, 01:12
Okay, so I have done alot of reading regarding how to get the best setup possible for this monitor. I have had it for a while now, and thought by making sure everything was running at 144hz, that would be the best choice for me, but I have found out I am far from wrong.
The trouble I am having is finding out exactly what I need to achieve the best I can out of this monitor, regarding the programs I need to download, I have CRU, but what else do I need and what do i need to change in the NVidia Control Panel under Adjust desktop size and partition to make sure this work.
I use 1920x1080 when not playing games.
I literally only play CSGO, and switch up between 4:3 1280x960 (stretched) and 16:10 1680x1050.
I have recently found out about 4:3 1440x1080 which is HD res of 4:3 1280x960, as I am aware.
(Also how would I go about say if I want to play on 4:3 but then I want to change to 16:10, is that something I do in the CRU app?)
16:9 1920x1080 - when not playing games
4:3 1440x1080 and 16:10 1680x1050 - CS:GO
These are the three resolutions I would love to setup so i get the most out of my monitor, I just have no idea on how to do it, and what needs to be turned off/on in the BenQ menu settings.
I am also using a DisplayPort Cable
I'm posting this because I have absolutely no experience with any of this and I'd rather be safe then sorry, I haven't found a tutorial or how to on a step by step guide on everything that is needed and what you shouldn't do etc. I just want to make sure I am doing everything the correct way not the wrong way. I have seen the countless posts here at blurbusters and from various other sites aswell, but I am still clueless as to what I actually need in regards to any programs and the correct way to go about all of this.
If anyone can help me out, I appreciate the time you have put in to help me in advance.
