trey31 wrote:To be honest I've been planning to wait until 2015
2020 is a more realistic year for 4K. We had HDTVs in the 1980s in Japan (MUSE HDTV, also known as Hi-Vision), they were insanely expensive. Took until the 21st century before HDTV became popular.
4K is coming, just not quick.
TheRulesLawyer wrote:I'm not sure 4k will ever be a 'thing' anytime soon.
Fixed it for ya.
The cost premium of retina displays is becoming small on smartphones, and SEIKI 4K displays show that it is possible to sell 4K HDTVs for less than $1000. They've been very popular among people like us because of their low price. Today, 1080p is standard even in cheap HDTVs (where 720p used to be the standard and 1080p was insanely expensive).
4K still benefits even 10 feet from a 50" TV
Also, during extreme cases such as
http://www.testufo.com/aliasing you can tell the difference between 1080p and 4K from 10 feet away from a 50" 4K HDTV, due to effects such as moire on unfiltered material (e.g. computer based games and mater, rather than television/movie material where they are often pre-filtered). The game industry is becoming more valuable than the Hollywood industry, you know... Some of us run HTPCs with our televisions now, and we've got XBox One and Playstation 3. In ten years from now, boxes will the horsepower to play 4K 60fps, and do it all with AA turned off -- and this is where 1080p versus 4K can make a
noticeable difference just as
http://www.testufo.com/aliasing shows...
4K 15Mbps still outperforms 1080p 7Mbps
There is also the fact that 4K 15Mbps streaming using HEVC actually looks pretty impressively good. Darn better looking than 1080p 7Mbps H.264 streaming -- I'd say about 4x better looking. Compression artifacts become half-sized at 4K than at 1080p, and compression artifacts are bigger than a pixel. Sure, there are some limitations that make a well-mastered Blu-Ray (25Mbps H.264) look a bit more artifact-free at close (5-feet) viewing distances than 4K online stream, but there is a balancing point that occurs where compression artifacts (which are half the size during 4K than during 1080p).
4K is more universal than 3D
You can downconvert 4K easily to any display. 4K is on the Moores Law path of the existing 2D television as the resolutions continues to increase, without needing to add any other things special (stereoscopic support). 4K is supported by more cameras than 3D. 4K is already in some smartphone and POV cameras costing under $500 and will become cheap/ubiquitous like 10 megapixel photos. 8K cameras will be similarly consumer-cheap someday, too. The NOKIA Lumia 1020 smartphone camera is 41 megapixels, enough to do 8K video footage -- once Moores' Law catches up. Especially if terabyte memory cards are available for 10 dollars at Walgreens. Why the hell not? Let's look at Fox, often broadcasting sports at 720p. Someday, Fox will have to replace 20-year-old HDTV equipment, and the only cameras they can buy are ultra-high-resolution cameras. They'd already have huge amounts of bandwidth then anyway, memory cheap anyway, and competing against everybody else, there would be no cost to forget 720p and just go higher def (whether it 4K or similar). Unless the only reason leftover to downconvert to 720p for broadcasting is to increase stadium ticket sales, but that doesn't affect Foxs' bottom line (and if it does, I wonder what labyrinthe framework allows that).
We're slowly moving away from the traditional channel metaphor
As we move away from the "antenna/cable-to-television" metaphor with the boom of boxes, converters, streaming, DVRs, and more -- we are essentially slowly (over time) moving towards a resolution-independent television world, where you can pretty much send any resolution, over any media, to any resolution display. We didn't have this luxury to easily watch PAL on an NTSC television in the 1970s, like today where some models of HDTVs have become essentially fully multisync (refresh rates in 1Hz increments, resolution in 1 pixel increments). Obviously, we have the scaling problem, but still 4K HEVC 15Mbps downconverted to 1080p actually looks better than 1080p H.264 7Mbps displayed natively, and is totally usable.
Streaming providers are more likely to bump up bitrates at 4K
Sure, we can do 1080p 15Mbps HEVC streaming to get to Blu-Ray quality over the Internet, more purer for 1080p displays, and that satisfies purists and videophiles I myself,
used to work in the home theater industry and used to have a
CRT projector 15 years ago (old page). So I understand where you are coming from. However, industry is more likely to do 4K 15Mbps HEVC streaming (to satisfy 4K users) even if it's watched on some 1080p displays. In this order, viewed at 1080p:
1080p 15Mbps HEVC
> 4K 1080p 15Mbps HEVC downconverted to 1080p
> 1080p 7Mbps H.264
Fortunately, the first two are closer together, than to the last one.
Traditional channel based TV will eventually become extinct in the next humankind generation
It is possible within 20 years in the western world, we will have no traditional "channel"-based broadcast television (at least at the pipe level). Already, switched digital video and IPTV is starting this migration, and eventually, all television becomes all random-access. Sure, user friendly boxes will still "map" them to channel numbers to keep old guys happy even twenty years from now, but it would no longer be channelized on a cable or radio waves anymore (and it is no longer, for IPTV). There would no longer be specific resolution standards, Fox could keep broadcasting at 720p if they wished, while the premium channels could stream 4K cheaply over the Internet to your television box, mapped as a specific channel on your box. Some DVRs now even let you press a button and it shows a VOD list of previous episodes of the show you are watching, and you can switch to them, Netflix/ITunes style! This ain't broadcast territory anymore. Channel-less media is going to explode in 4K choices, leaving broadcast behind in the dust.
We are now entering the infinite channel-free universe
There is no longer any limit to the number of channels a television can receive, if you count Internet-based services. There is no longer any need to push channels off the dial to add more popular content. Television is the analog phone, while YouTube/IPTV/Netflix/iTunes/VUDU/HBO Go/ESPN Online is the modern smartphone of television. Some of those non-broadcast services are now beginning to offer 4K shortly. In Canada, 1 in 7 people is dropping cable or indicated plans to drop cable. Even my dad, 79 years old, does not have cable, but figured out how to watch CBC News on his HDTV, by connecting a cable between his Mac and his HDTV. (He already has an AppleTV, a Netflix box that one of the stepsons got).
My dad, a person who has difficulty learning how to use a new computer, is a cord-cutter! Can you believe it? I never told him to cut the cord, he just figured it out, and did it. He doesn't care what resolution he watches in, some of the stuff shows up blurry and some of the stuff shows up sharp. (his Apple products, including AppleTV, correctly automatically detected 1080p and has switched to that). Likewise, when the boxes start supporting 4K, his TV is going to benefit anyway, due to 4K 15Mbps looking better than 1080p 7Mbps anyway. Dad becomes 80 this March. Broadcasters, alarm bells. Pay attention.
We are becoming resolution independent
Likewise, the same thing is about to start happening to resolutions of broadcast material -- we are on the cusp of it. So 1080p, 720p, 4K, 8K -- it becoming less and less rigid. We watch 1080p material on our Retina IPADs, YouTube added a 1440p video mode, smartphones are now increasingly used as TV devices but they dont match TV resolution. New streaming material occasionally pops up that are not of the traditional resolutions. Our digital cameras almost never takes pictures exactly the same resolution as our TV; but the pictures still display well anyway! The same thing is gradually happening to video today. Oh, and some sub-$500 cameras can now do 4K today (e.g. GoPro Hero3) and some smartphones. Eventually, it'll be ubiquitous to the point where we have all-4K cameras and televisions where 4K is only $50 more. People start posting 4K videos. Broadcasters grab 4K footage from consumers for reality stuff or news (e.g. capturing a fire disaster, or citizens taking pictures of a war scene). Still photos now far exceed 1080p, too, and the same will be for video.
Moore's Law
Enough said. Far more slowly than chips, but still progressing.
New generation of kids
The pre-smartphone/pre-Internet people won't care a hoot, but little kids growing up on Retina displays today, are today more frequent complainers of low-quality video. Just play VHS at them all day long and see how they react (this might be a form of forture -- it looks worse than crappy phone camera footage).
Bigger vision coverage for cheaper
Computer monitor viewing distances is where 4K benefits a lot (1:1 screen width). People are using televisions less and viewing screens at arms lengths more often nowadays. The day will be coming when people stream 4K to their 4K tablets, and it definitely will look better than 1080p. Those that use televisions will get bigger and cheaper televisions -- average size of TVs are much bigger today than the average size of TVs 20 years ago. There is no reason to see this progress stop -- for example, if 80" pin-up rollable TVs becomes available in the bargain bin at Walmart for $100, that is a route to bigger sizes at less inconvenience. Wearing Google Glass / Oculus VR / etc product where you can get the apparent look of a 100" TV 10 feet from your retinas -- 4K would benefit such eyewear/VR/etc (if such devices become popular). Traditional television will probably still be popular, but let's observe TV store of the 2010s (all flat panels) looks very different from the TV store of the 1990s (small boxy tubes and big projection boxes), and with lower numbers attached to their price tags. 4K is a minor jump compared to the 1990s versus 2010s.
Broadcasters now have to compete with Average Joe Users
Eventually, it becomes cheap for Mom & Pop to start a 4K streaming station with cheaper bandwidth (20 years into the future), and any of the hundreds of brands of boxes in the future can decide to pick up that and feature it (e.g. assign it a channel number on their display, or assign prominent icon, etc). And it would cost almost nothing to run your own 4K television broadcast. In fact, it's already sort of happening now -- YouTube is built into your TV. You're watching Mom & Pop Channel Today already, via the YouTube feature. Wake up world: Some popular YouTube channels have more viewers than half of the TV channels on your Comcast settop box!
Average Joe Users can cheaply upload better quality video than broadcasters today
Now imagine this in the 4K era, where mom & pop can broadcast better quality video than the television broadcasters. We can do this now, today. Some of us are putting 4K material online today, reasonably cheaply, and broadcasting them cheaply, bypassing traditional carriers. Obviously, sharp, good video, doesn't make a good program/movie/show, but as you've witnessed, there is a boom of YouTube stars being moved to broadcast television too as well. Niche stuff such as
Video Game High School, a television-style show that will also become available as 4K downloads. The kickstarter campaign has gotten 33% of its goal in just only the first 3 days of campaign, and at that rate, it's a sealed deal. Have this happen 100 times more, and broadcasters are _definitely_ going to wake up regarding 4K. Kickstarter funded television shows (that has more viewers than many TV channels do) will eventually force the infinite channelless universe upon us.
Evolution of television interfaces welcomes 4K easily
Now imagine floating 20 years into the future. Descendants of YouTube, Netflix, Cable, etc -- merging into the same infrastructure -- you buy 5 channels from Comcast, 7 channels from Verizon, and 3 channels from ESPN, and use your SuperBox2030 to view them along with SuperNetflix and UltraApple or whatever they will call them. Maybe channels numbers will still exist in that box. Or maybe it'll all be mostly menu driven (e.g. Comcast might even someday earn more money from menu-driven Internet television interfaces, ala Netflix style) with a live broadcasts section and a non-live section. We don't know how television interfaces will evolve over time, but one just need to turn their head to Netflix, and the early rumblings of cable companies making certain channels available on the Internet, and glimpse the future. Obviously, legal and regulatory barriers apply, but now of a sudden traditional television have to complete against tons of cheap, better 4K content that are equally as easily streamed over the Net, and prone to "Apple-ization" (not necessarily by Apple). As in parlance of "Forget AMCE Cable. Our TV service is Retina quality!!!". There are market innovations waiting in the wings, too.
You honour, I rest my case. I think I have hereby proven that 4K (or similar-league resolutions) is coming. Just not quickly, and just not in the way you think.
