Hello homies. Like the topic say, im interested in all your settings for gaming/browsing/movies.
I can't seem to find any good settings, and allways end up changing stuff!
Mostly i play CSGO/SC2 and want the best settings possible!
Your XL2720Z v2 Settings gaming/browsing/movie ?!
Re: Your XL2720Z v2 Settings gaming/browsing/movie ?!
I cant seem to tweak this monitor very much do to the overly high gamma. this seems to be a good FPS monitor but for everyday use the gamma seems way to high. running the windows calibration tool or nvidia control panel I have to turn the gamma really far down to get a picture that isnt washed out and inaccurate over all. I have followed all the tweaks suggested even tried 4 different ICC profiles (btw they all lower gamma drastically) the monitor is fantastic in FPS modes with and without AMA but for everyday use it has been a struggle. Using DPort at 144hz. also other monitors I have all look descent on my PC. 780ti classified. GPU
Gaming Profile.
Games used on. CSGO, BF4.
FPS1 profile
AMA: High
Blur Reduction: off
Instant Mode: On
Black EQ: 20
Low Blue: 0
Brightness: 85
Contrast: 50
Gamma: 4
Sharpness: 7
R: 98
G: 97
B: 100
Gaming Profile.
FPS1 profile
AMA: High
Blur Reduction: off
Instant Mode: On
Black EQ: 20
Low Blue: 0
Brightness: 85
Contrast: 50
Gamma: 4
Sharpness: 7
R: 98
G: 97
B: 100
- lexlazootin
This reminds me of the audio world were people would use different EQs for different styles of music when in reality there should only be one setting...settings for gaming/browsing/movies
Accurate.
lexlazootin wrote:This reminds me of the audio world were people would use different EQs for different styles of music when in reality there should only be one setting...settings for gaming/browsing/movies
Accurate.
Would you consider the colors in CSGO for example as accurate? gotta set saturation at 200.
And EQ depends on the mix/mastering and the system you listening thru
- lexlazootin
You should be viewing it how the devs intended. The game is a bit dark and a little washed out on some maps but that's the their job to fix that, not for everyone else to change the settings.
If i made a horror game and intended for it to be dark, it's my job to get that right, not for everyone else to do that for me.
If you have a accurate system and the song was mixed correctly, there shouldn't be any problem because i'm listening to it how the artist intended. It's all the same.
