Hi, I manily play CS:GO but want a TN monitor that is good for other things as well in case I want to play other games in the future, but I don't want to spend way more than I need. I want the best input lag/response time and
BenQ XL2420G is 1 I am considering, I can get 1 for about $390.
OTHERS:
BenQ XL2430T - looks to be good after color settings are changed - $290
BenQ XL2420Z - solid monitor but I am favoring the 2430 - $300
BenQ XL2720Z - I have heard 27's have more input lag, also I don't think I need this big and Id rather buy the 2420G than spend - $360
Does G-Sync increase input lag/response time like I have read some places? And if so by very much? Is it even worth me buying the 2420G if I am not playing many newer games that use the technology? I don't mind spending extra if it is worth it, but if it going to be worse for CSGO and I do not need it I will go with the 2430T, I have heard some ppl say the G is great for CSGO and some say it is worse or not worth it so I wanted to ask people that actually KNOW how the monitors work and aren't just spewing BS opinions.
Main concerns:
1. input lag
2. price (id rather buy a mechanical keyboard and save $100 unless the 2420G is really best then I will buy it and wait for keys)
3. colors (I have heard these all can be adjusted so out of the box settings aren't that important and I imagine most of these can be calibrated to look pretty similar, but if 1 has way better tech and meets my needs LMK)
TLDR: I am basically torn between the 2430T and 2420G unless someone gives me a reason to buy something else. Wondering if I need GSync and if it decreases performance.
THANK YOU! And Happy Holidays =)
Which BenQ to buy? BenQ XL2420G or others
- lexlazootin
Re: Which BenQ to buy? BenQ XL2420G or others
Well all of these monitors are pretty much have 1~ms difference from each other so they are all good.
If setup correctly (Having your fps capped at 140 in CSGO) there is pretty much no difference.
Pretty much every game can use GSync.
>Is G-Sync worth it?
My opinion is god yes! i love playing CS:GO with g-sync. No more screen tears and my fps is caped too 140 so my GPU doesn't have to run 100% all the time playing CS:GO. Playing games like Fallout 4 is smooth as butter.
>Is G-Sync worth it?
