Frame skipping result
joaofsa2000
Post by joaofsa2000 » 10 Jan 2016, 11:30
i have this TV for 4 years its a chinese brand i think bought it for 100 euros and here it is the frame skipping result
compared to the good picture in the website i can say my moniter passes the test even though its a cheap one dont know if its a good thing or not. hope someone can explain what the result means
EDIT: ok now i understand what this is meant for. i tried to overclock mine but it doesnt work so i will just leave it to that
Re: Frame skipping result
Post by RealNC » 10 Jan 2016, 13:19
The frame skipping test is for verifying that the screen isn't skipping frames when you overclock it. You're running at 60Hz, so there's no point in running this test.
spacediver
Post by spacediver » 10 Jan 2016, 14:31
If frames were beings skipped, then there's a chance that one of those patches that are lit up would be empty. The fact that you have a sequence of squares that are all lit up indicates that none of those frames were skipped.
