Been almost 2 years since i got my Benq XL 2420 Z hooked up to my MSI 780 ti. (i had 1 more Benq XL2420z and 1 more 780ti but i split them to upgrade the other PC downstairs).
Recently at the IT show here in Singapore I walked past this beauty of a monitor the Acer Predator X34. I was probably one of the few that was more interested in the monitor than the 2 scantily clad Taiwanese brand ambassadors.
I won't talk more about the qualities of the X34 as all the reviews are available online, but my question is, IS IT WORTH IT?
I have some concerns which I hope you Blur Bosses can help out:
1) My current set up is drawing 1920 x 1080 at 120mhz. Will switching to 3440 x 1440 at 100mhz be too much monitor for my feeble 780ti OC GFX card or will i need to upgrade my GFX card as well?
2) The main attraction for me on the X34 is that it is IPS with 98% color reproduction AND G-Sync AND has 4ms GtG AND operates at 100mhz. Will the quality of colors be much noticably better on the X34 vs a calibrated XL2420z? And would i lose too much blur reduction to achieve this color?
3) my CPU is an i5 3570k... will that be enough to handle the X34 in G-Sync or will i experience lag from my hardware unable to keep up with my monitor?
Hope you guys can share your thoughts on the above, would really appreciate it!
