XL2411Z Frame Skipping?
makitofikito
Post by makitofikito » 17 Mar 2016, 15:23
Hello, so I stumbled across one thread at Reddit saying one of the AOC monitor is known to have problem with this, I had a strange feeling about my monitor since I had, but I never tried this test, so I decided to do so.
Result:
https://i.imgur.com/0PASLVI.jpg
I set camera on 1/5.
I already have this monitor over a year, but I never think about that, and if it is a failure, can i get a replacement?
lexlazootin
Re: XL2411Z Frame Skipping?
Post by lexlazootin » 17 Mar 2016, 18:28
Yea, that's pretty bust and defective.
AOC really like to cut corners with their monitors.
makitofikito
Post by makitofikito » 17 Mar 2016, 19:27
Ouh :( Are you 100% sure of that? should i send it back?
Falkentyne
Post by Falkentyne » 17 Mar 2016, 20:20
Are you using a VT Tweak?
lexlazootin
Post by lexlazootin » 17 Mar 2016, 22:18
makitofikito wrote:Ouh :( Are you 100% sure of that? should i send it back?
If your monitor says it's 144hz then it should be displaying 144 frame a second.
Skipping frames is pretty bad thing, i think you might be able too make it not frame skip by creating a custom resolution in your GPU control panel at 1080p 144hz but with reduced blanking.
i'm not 100% sure this will help but it's worth a shot.
makitofikito
Post by makitofikito » 18 Mar 2016, 06:47
Falkentyne wrote:I don't know, i was tinkering with it while ago while i was trying to use blur reduction, but in the end i didn't like it so i switched, could that be the cause?
makitofikito
Post by makitofikito » 18 Mar 2016, 07:13
i restarted cru settings and its the same i think..i can see that empty gap even without picture :(
Falkentyne
Post by Falkentyne » 18 Mar 2016, 11:22
Run reset-all.exe from CRU, restart the driver (restart64.exe) or computer, then try again. This will remove all custom resolutions.
And is instant mode enabled or disabled in the OSD?
makitofikito
Post by makitofikito » 19 Mar 2016, 07:52
Instant mode on
