ViewSonic XG2401 refresh rate paradox
Posted: 25 Jun 2016, 14:24
by dreamer
Hello everyone,
I just found a conflicting spec about XG2401.
http://www.viewsoniceurope.com/eu/produ ... php#pSpecs
You can see from the specs the frequency is 24-120hz. Isn't it supposed to be a 144hz monitor.
Is it overclocked or something? or just an amateur typo?
Re: ViewSonic XG2401 refresh rate paradox
Posted: 25 Jun 2016, 17:43
by Q83Ia7ta
Posted: 25 Jun 2016, 17:56
by dreamer
So it's just a typo then.
Still it's weird they made that type of mistake.
Is there a way to understand that if the panel is overclocked or not?
Posted: 25 Jun 2016, 21:25
by Falkentyne
No it's not a typo.
144hz is *STILL* not a standard refresh rate, as far as timings go.
In normal frequency range and timings, refresh rates usually go up only to 123-128 hz.
Officially it's 123hz, which is why ToastyX Custom resolution utility will not allow you to enter a standard refresh rate higher than 123hz.
Whether anything higher than 123hz works depends purely on the monitor firmware.
Once you go past that (usually 129hz+), you need reduced blank (Lower vertical total).
Posted: 26 Jun 2016, 05:43
by dreamer
Falkentyne wrote:No it's not a typo.
So does that mean it's overclocked? I didn't see any other 144hz monitor having 120hz max freq. range in datasheets.
Also it says 24-144 here for example
http://gaming.viewsonic.com/XG2401/ Why these specs are conflicting. Really weird.
Posted: 26 Jun 2016, 06:21
by Q83Ia7ta
It's typo. All 24" TN 144Hz monitors based on same lcd panel so it doesn't matter overclocked it or not.
Posted: 26 Jun 2016, 10:15
by dreamer
Q83Ia7ta wrote:It's typo. All 24" TN 144Hz monitors based on same lcd panel so it doesn't matter overclocked it or not.
Didn't know that. Which panel they use?
Posted: 26 Jun 2016, 16:31
by Falkentyne
I think he's referring to the AU Optronics M240HW01 I think.
Pretty much every 1080p 144hz TN uses this. Even the LG 24GM77 was proven to use this.
Posted: 26 Jun 2016, 18:43
by Q83Ia7ta
dreamer wrote:Q83Ia7ta wrote:It's typo. All 24" TN 144Hz monitors based on same lcd panel so it doesn't matter overclocked it or not.
AUO M240HW01 V8
