Hi to all, i have Vg248qe with the kit installed, i can't uderstand how to set the g-sync.
My spec:
i7 6700
gtx 1070 fe
windows 10 annyversary update installed
Can someone please explain to me what i need to put in setting in nvidia controll pannel?
Help for set G-sync
- sharknice
Re: Help for set G-sync
In advanced settings in the nvidia control panel under the display tree there is "Set up G-SYNC"
If you don't have that option try updating your drivers.
