Advice on IPS for gaming
Posted: 04 Feb 2014, 23:58
by runf
I know this is lame but I've read a lot about monitors for gaming and I'm still undecided.
I just want as many comments and recommendations as I can get before buying.
I have an Asus VE247H which I bought in a panic when my previous monitor Samsung 2232GW went bad.
I play adventure and FPS. Half life 2, Skyrim,Crysis, Far Cry, Dishonored, etc.
I just don't get enough contrast I think. For instance, in Skyrim, in the caves (there are a lot of caves), the grays just meld together and I can't see detail. In other games, in dark scenes, I either can't see enough detail or if I put the monitor on the "game" setting, (I do like the "Splendid" feature on this monitor) everything is bright, but washed out.
I'm a older guy and I don't game competitively, I've never even played a co-op and I'm not even particularly good. I just do it for fun.
I was about to go for the Benq that everyone raves about but then I started to read about IPS monitors and how they have a superior picture. I REALLY like to look at the art work in many games but I don't want a slow, pixelated experience either.
I'm currently interested in the ASUS PA248 and perhaps the Dell UltraSharp U2412M. Also, I'd like to know the difference between the above Asus and the Asus PA249Q.
I have a GTX 660 and an i7-950.
I'd love to hear opinions. Thanks.
Re: Advice on IPS for gaming
Posted: 05 Feb 2014, 01:38
by SS4
Between the asus and the Dell the asus is slightly more suited for gaming since the panel is more responsive.
As for the difference between the 2 asus, the 249 uses a 10 bit panel instead of an 8 bit meaning you get a broader color spectrum (from 16.7 mil to over 1 billion) but unless you do professional work the difference is minimal and you probably wont notice it anyways.
You could also look at overlord who make overclocked IPS monitor.
But 60 hz might be enough since you're only sporting a 660 in that PC so itl be easier to turn up the eye candy on the lower resolution of the asus (1200 instead of 1440).
If you want more accurate details im sure others will give their input as well :P
Posted: 05 Feb 2014, 02:21
by Black Octagon
OverclockABLE (not overclocked) monitors :)
If going IPS, I would recommend Overlord. Love my Tempest at 120Hz, even if there is some motion blur due to the slowish pixel transition time
Sent from dumbphone (pls excuse typos and dumbness)
Posted: 05 Feb 2014, 03:35
by shadman
Sounds like you'd really do well to get an IPS monitor. I play Battlefield mostly, a decently fast-reaction FPS, but I love my IPS monitor (Catleap at 120Hz).
Whether or not you should get an overclockable IPS monitor such as the Q-Nix / Overlord, or a regular 60Hz model could be decided between two factors: Price, and other devices to be used with the display.
It is worth noting that the quality of the Q-Nix is on average a bit lower than the Catleap/Overlord monitors, and when overclocked usually dim the screen a bit, but this can be helped. Some people say you get close to what you pay for, and so the Q-Nix/X-Stars can be found pretty cheap around $325, and the Overlords at a little higher quality are a bit higher at around $500 or so.
The second factor is just asking a question: Are you going to use this display with any other devices? The Overclockable displays will only have a Dual-DVI input, so a dedicated graphics card is a must for anything with these monitors, period. If you go with a route to another monitor, such as the ones you linked, you should be good to plug just about anything in it, provided the ports on the monitor.
Of course, this is only if you are considering an overclockable display, and 2560 x 1440p. I just wish for people to know pro's/cons regarding these. If you want to stay with major-name brands, get longer warranties and more ports, and keeping the 1080p/1200p resolution, I do like the look of the Asus PA248. I believe that would be a good monitor for your needs, to not worry about some other caveats on the OC models that do not bother other people. Especially since it looks like the Asus goes to 75Hz, which will help with some motion blur. SS4 seems to have described the differences between the two Asus units, but I can't tell if the PA249Q does >60Hz.
Posted: 05 Feb 2014, 04:24
by nimbulan
If you're concerned about contrast, it would be worth looking into a VA panel monitor. They have by far the best contrast ratios compared to IPS and TN and still have full 8 bit color. Eizo even sells a 120 Hz model though it's very expensive. I haven't used a VA panel myself though, so perhaps someone who has used a recent VA panel can recommend a model to consider.
Posted: 05 Feb 2014, 15:26
by runf
Thanks for everyone's comments. I'm leaning towards the Asus PA248.
I forgot to mention that I want to stick with 24". I don't want to get into overclocking. Also, I'm not quite ready to get a new video card so I think 144hz will have to wait for me. Also I think the standard 1080 resolution will be fine for me if the colors are great.
Posted: 05 Feb 2014, 19:39
by shadman
Good choice, please let us know how it goes when you do get it! I'd love to hear your opinion.
Posted: 11 Feb 2014, 02:34
by runf
I'm loving the Asus PA 248Q. The color is superb and I don't notice any performance hit at all.
Posted: 11 Feb 2014, 16:34
runf wrote:I'm loving the Asus PA 248Q. The color is superb and I don't notice any performance hit at all.
Glad to know that you're enjoying it! Among 60Hz, it's among the best 60Hz can offer these days.
If you someday decide to leap to 120Hz in the future -- then check out the Blur Busters 1440p 120hz IPS Guide and make a decision about whether to go the LightBoost/ULMB/Turbo240 route, or the overclockable IPS route.
Posted: 16 Feb 2014, 23:39
by SS4
Nice, I'm glad that you followed my advice and werent disapointed :P
Have fun and hopefully we can kill each other in an online FPS soon lol
