How to bypass 'this is 85hz override' message?
Posted: 03 Mar 2017, 19:03
So I was able to overclock my monitor Philips 273EL to 76.979 Hz:
http://i.imgur.com/LPYyQlC.png
But once I set refresh rate above 76.979, monitor still works, but I get this message in the center of the screen for ~5 seconds, saying:
Is there a way to somehow edit firmware of the monitor(or do something else), so it doesn't show this message? I mean, monitor works at 84 Hz but I get this message and it's unplayable with this message.
Information about my monitor from MonInfo:
I'm stuck.
Need help, gurus. Thanks in advance!
Then it disappears for like 30 seconds and then I get this message for ~5 seconds, again.This is 85Hz override,
change computer display
input to 1920X1080@60Hz
Code: Select all
Monitor
Model name............... Philips 273EL
Manufacturer............. Philips
Plug and Play ID......... PHLC07C
Serial number............ AU51303009475
Manufacture date......... 2013, ISO week 3
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 600 x 340 mm (27,2 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... Supported
MCCS revison............. 2.2
Display technology....... TFT
Controller............... Novatek 0x0
Firmware revision........ 1.0
Firmware flags........... 0x00000070
Active power on time..... 22187 hours
Power consumption........ Not supported
Current frequency........ 83,50kHz, 77,00Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,644 - Ry 0,336
Green chromaticity....... Gx 0,295 - Gy 0,611
Blue chromaticity........ Bx 0,146 - By 0,070
White point (default).... Wx 0,313 - Wy 0,329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-83kHz
Vertical scan range...... 56-76Hz
Video bandwidth.......... 170MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1920 x 1080p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 75Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
Report information
Date generated........... 04.03.2017
Software revision........ 2.90.0.1020
Data source.............. Real-time 0x0011
Operating system......... 10.0.10240.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,41,0C,7C,C0,03,25,00,00,03,17,01,03,80,3C,22,78,2A,CA,45,A4,56,4B,9C,25,
12,50,54,BD,4B,00,D1,C0,81,80,95,0F,95,00,B3,00,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,56,50,21,00,00,1E,00,00,00,FF,00,41,55,35,31,33,30,33,30,30,39,34,37,35,00,00,00,FC,00,50,
68,69,6C,69,70,73,20,32,37,33,45,4C,00,00,00,FD,00,38,4C,1E,53,11,00,0A,20,20,20,20,20,20,00,0FNeed help, gurus. Thanks in advance!
