ok it seems it still hasnt worked yet
the last commands
ubuntu@ubuntu:~/flashrom$ sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49 -c "MX25L1605A/MX25L1606E" -r backup.bin
flashrom v0.9.7-r1846 on Linux 4.8.0-36-generic (x86_64)
flashrom is free software, get the source code at
http://www.flashrom.org
Calibrating delay loop... OK.
Info: Will try to use device /dev/i2c-1 and address 0x49.
Info: WILL reset the device at the end.
Found Macronix flash chip "MX25L1605A/MX25L1606E" (2048 kB, SPI) on mstarddc_spi.
Reading flash... done.
ubuntu@ubuntu:~/flashrom$ tr '\000' '\377' < /dev/zero | dd of=firmware.bin bs=1k count=2k
2048+0 Datensätze ein
2048+0 Datensätze aus
2097152 bytes (2,1 MB, 2,0 MiB) copied, 0,0104606 s, 200 MB/s
ubuntu@ubuntu:~/flashrom$ dd if=XL2411Z_V4.BIN of=firmware.bin conv=notrunc1664+0 Datensätze ein
1664+0 Datensätze aus
851968 bytes (852 kB, 832 KiB) copied, 0,00999706 s, 85,2 MB/s
ubuntu@ubuntu:~/flashrom$ sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49 -c "MX25L1605A/MX25L1606E" -w firmware.bin
Reading old flash chip contents... done.
Erasing and writing flash chip... Erase/write done.
Verifying flash... FAILED at 0x00000000! Expected=0x02, Found=0xb0, failed byte count from 0x00000000-0x001fffff: 0xfe
Your flash chip is in an unknown state.
Please report this on IRC at chat.freenode.net (channel #flashrom) or
mail
[email protected], thanks!
ive got now a full blackscreen cant turn the screen on
