*** Official LIST of G-SYNC Monitors ***
Post by Chief Blur Buster » 30 Mar 2017, 21:37
Hello,
This is a newly updated list:
List of G-SYNC Monitors
If you see missing monitors, let us know!
Cheers,
Re: *** Official LIST of G-SYNC Monitors ***
Post by RealNC » 31 Mar 2017, 05:57
Small bug: Sorting by refresh rate doesn't sort correctly. (60Hz messing things up even here :mrgreen:)
Post by Chief Blur Buster » 31 Mar 2017, 12:00
RealNC wrote:Small bug: Sorting by refresh rate doesn't sort correctly. (60Hz messing things up even here :mrgreen:)
Fixed. :) Thanks!
Now Refresh Rate sorts correctly.
StEaK
Post by StEaK » 31 Mar 2019, 13:28
You forgot the MSI Oculux NXG251R.
LagBuster
Post by LagBuster » 28 Feb 2020, 18:35
That link (http://www. blurbusters.com/gsync/list) redirects to the FreeSync monitors list, not the G-Sync monitors list.
Post by Chief Blur Buster » 28 Feb 2020, 21:55
LagBuster wrote:
28 Feb 2020, 18:35
That link (http://blurbusters.com/gsync/list) redirects to the FreeSync monitors list, not the G-Sync monitors list.
Good catch, fixed the link.
If you remove "www." from blurbusters.com it works correctly. http://blurbusters.com/gsync/list
So we've found a Redirect bug -- fixing that this weekend --
So that both https://www.blurbusters.com and https://blurbusters.com works the same.
Kaled
Post by Kaled » 30 Jun 2023, 08:54
Should I be worried that the Asus OLED PG27AQDM isn't on Nvidia's list of G-SYNC Compatible Monitors here? > https://www.nvidia.com/en-us/geforce/pr ... ors/specs/
nSarval
Post by nSarval » 25 Apr 2025, 08:17
I think the Omen X25f is compatible with G-Sync. I don't use G-Sync but i think it is available.
