blur buster strobe utility on ps4
nathan02
Post by nathan02 » 07 Apr 2017, 22:35
hi guys im new to this strobing and blur reduction thingh
i have a benq xl2730z.. i wanted to use the blur reduction when playing on my ps4.. but obviously its dark when blur reduction is turned on
how do i make it more brighter??
they said use Blurbuster utility but I dunno how to apply it when playing ps4
Re: blur buster strobe utility on ps4
Post by Chief Blur Buster » 08 Apr 2017, 10:46
1. You adjust 1920x1080 60Hz while HDMI is connected to a PC. (But it may be easier to use the Service Menu)
2. Adjust Strobe Utility or Service Menu accordingly (the "Persistence" or "Duty Cycle")
3. Now reconnect monitor back to PS4.
Falkentyne
Post by Falkentyne » 08 Apr 2017, 12:35
Chief, I'm not sure if persistence and crosstalk will work on the PS4. The output is 60hz, and the XL2730Z is not capable of single strobing at 60hz. On the XL2720Z, if single strobe is off, it ignores the strobe duty and strobe phase settings below 100hz.
The XL2730Z is bugged, so it's possible the settings may still work. At 100hz for example, blur reduction is unusable because it strobes at 120hz timings, causing an out of sync picture (unusable), this was verified in tftcentral's XL2730Z review. Same thing happens at 85hz. So if its using 120hz settings at 60hz, Area and Intensity settings may still work. But if it's using a separate 60hz setting like the XL2720z, XL2420Z and XL2411Z (Single Strobe=off), they may be ignored.
Try it and report back.
Note: XL2735 fixed the broken 100hz setting, and it officially double strobes at 60hz, 75hz and 85hz.
TBH you're not going to get much improvement on the XL2730Z with 60hz double strobed blur reduction. Try it, but for some people, double strobing just looks bad.
nathan02
Post by nathan02 » 09 Apr 2017, 05:29
Falkentyne wrote:Chief, I'm not sure if persistence and crosstalk will work on the PS4. The output is 60hz, and the XL2730Z is not capable of single strobing at 60hz. On the XL2720Z, if single strobe is off, it ignores the strobe duty and strobe phase settings below 100hz.
hey mate can you help me how to do it. step by step guide please. much appreciated
nathan02
Post by nathan02 » 09 Apr 2017, 06:01
its not dark anymore but motion blur is still visible when playing ps4 games on my xl2730z.. how do i make motrion blur gone..
nathan02
Post by nathan02 » 09 Apr 2017, 06:46
Chief Blur Buster wrote:1. You adjust 1920x1080 60Hz while HDMI is connected to a PC. (But it may be easier to use the Service Menu)
sir can you guide me step by step////
i read on your previous post wayback in 2014 that 60hz is not applicable on motion blur
im playing with a ps4 which has 60hz only . how do i manage to remove motion blur using my benq xl2730z. step guide please
Falkentyne
Post by Falkentyne » 09 Apr 2017, 09:57
We already told you the monitor DOUBLE STROBES at 60hz.
Double strobing looks not much better than no motion blur at all.
Please don't be so pushy and demanding. It's really impolite.
If you wanted good motion blur reduction on a PS4, you would have been better off buying an XL2411Z, XL2420Z (discontinued), XL2430T or XL2720Z, and turning on the "Single Strobe" service menu option. The newer Benq monitors removed this option and will not do good blur reduction at 60hz refresh rate.
nathan02 wrote:im playing with a ps4 which has 60hz only . how do i manage to remove motion blur using my benq xl2730z. step guide please
Only use motion blur reduction at 120hz and 144hz on this monitor.
Post by Chief Blur Buster » 09 Apr 2017, 16:24
Falkentyne wrote:We already told you the monitor DOUBLE STROBES at 60hz.
Easy both of you....
Readers do need to be patient but we should also be patient back to them too :)
Anyway, back to this, Blur Busters Strobe Utility does not support the BENQ XL2730Z so I would not be able to give you a step-by-step guide on this.
Also, it is true that the XL2730Z double-strobes at 60Hz, and there is no way to bypass this.
Falkentyne
Post by Falkentyne » 09 Apr 2017, 19:21
Sorry Chief I wasn't trying to be rude. He was literally ignoring what we said and -demanding- help even when we already helped. That put me over the edge.
Let's try it this way.
If you want blur reduction on consoles (that are limited to 60hz output), you either want a CRT or other monitor or device with strobing (CRT's, maybe some plasma TV's), Sony televisions which have motionflow impulse (Sony tech), or several Benq monitors (XL2411Z, XL2420Z, XL2720Z, and XL2430T only; you will need to go into the service menu and enable the "Single Strobe" option, and then set Strobe Phase to 000 (lowest crosstalk, but 1 frame higher input lag), or 100 (more crosstalk at the bottom, but up to 1 frame faster response). This is the only option you have at this present time.
nathan02
Post by nathan02 » 09 Apr 2017, 21:17
Falkentyne wrote:Sorry Chief I wasn't trying to be rude. He was literally ignoring what we said and -demanding- help even when we already helped. That put me over the edge.
you said mate there is a bug on this monitor where i can still use singke strobe in 60hz. maybe i can try that?
i really like my benq,. for pc gaming its a hell of a great experience. maybe im just not used to console gaming yet lol.
