OLED 4K 30" 60 Hz - Dell UP3017Q
Vega
Post by Vega » 12 Apr 2017, 20:25
Overview
Realistic beyond belief. Color beyond compare.
Experience vivid color against true black on our first OLED monitor. Featuring a 30-inch Ultra HD 4K screen with PremierColor.
Beautifully lifelike: Images are intensely real against OLED’s true black with the highest contrast ratio yet – at 1,000,000:1.
Greater depth and detail:Magnify every hue with PremierColor qualities for precise, factory-calibrated color.
Outstanding connectivity and design:A single USB Type-C cable eliminates clutter, transmits Ultra HD 4K signals and audio, and supplies power to your laptop.
Unmatched reliability:Count on dependability with a Premium Panel Guarantee from the world’s No. 1 monitor brand.
Manufacturer Part# : J3CJM
Dell Part# : 210-AIEI
Tech Specs
Display
Diagonally Viewable Size
76.19 cm (30 inches)
Preset Display Area (H X V)
699.86 mm x 379.22 mm
27.55 inches x 14.93 inches
265400.90 mm2 (411.32 inches2 )
Aspect Ratio
16:9
Panel Type, Surface
OLED
Maximum Preset Resolution
3840 x 2160 at 60 Hz
Curve radius (if applicable)
NA
Border Width (Edge of Monitor active area)
11mm (Top/Left/Right). 16mm (Bottom)
Viewing Angle:
178° vertical / 178° horizontal
Pixel Pitch
0.173 mm x 0.173 mm
Pixel Per Inch (PPI)
147
Contrast Ratio
1000,000:13
Backlight Technology
NA
Brightness
300 cd/m2 (typical) / 0.0005 cd/m2 (min)
Response Time
0.1 ms (black to white)
Wireless Charging Feature
NA
G-SYNC Suupport
NA
PbP/PiP
PbP (No)
PiP (No)
Daisy Chain Availability
No
Dell Display Manager Compatibility
Yes with Easy Arrange
Remote Asset Management
Yes, via Dell Command
Color Support
Color Gamut (typical):
Adobe RGB 100%
Rec709 100%
DCI-P3 97.5%
Rec2020 85.8%
Color
Depth:
1.07 Billion colors (10 Bits)
Color Calibration SDK SW
No
Color Calibration with X-rite colorimeter
No
Display Screen Coating:
AR (Anti-Reflection) reflectivity: 4.5% Hardness 2H
Audio Output:
No
General
Connectivity
mDP (1.2)
HDMI (2.0)
USB Type C
What's in the box
Monitor with stand
Power cable and adapter
1 x mDP -DP cable
1 x mDP -mDP cable
1 x HDMI Cable
1 x USB type C cable (C to A)
1 x USB type C cable (C to C)
1 x USB Type C Holder
Cleaning cloth
Drivers and documentation media
Quick setup guide
Safety Information
Stand
Vertical Stand Extension (100 mm)
Tilt (5°/21°)
Swivel
Pivot( clockwise / counter clockwise)
Built in cable-management
Flat Panel Mount Interface: VESA (100 mm)
Built-in Devices
USB Type C (Alternate mode with DP1.2, Power Delivery PD up to 100W)
Security
Security lock slot (cable lock sold separately)
Anti-theft stand lock slot (to panel)
Compliance and Standards
TCO Certified Displays
RoHS Compliant
Service/Support Details
3-Year Advanced Exchange Service with Premium Panel Guarantee and Dell Prosupport
Size and Weight
Dimensions with stand (H x W x D):
Height: Compressed : 456.3 mm (17.96 inches), Extended : 556.3 mm (21.90 inches)
Width: 686.2 mm (27.02 inches)
Depth: 191.6 mm (7.54 inches)
Dimensions without stand (H x W x D):
Height: 405.4 mm (15.96 inches)
Depth: 44.7 mm (1.76 inches)
Weight
With packaging: 19.31 kg (42.56 lb)
Panel only: 6.43 kg (14.17 lb)
Electrical
Voltage Required:
100-240V AC / 50 or 60 Hz ± 3 Hz / 3A (maximum)
Power Consumption (Operational):
105W (typical) / 240W (maximum)
Power Consumption Stand by / Sleep
Less than 0.5W
Environmental
Temperature Range
Operating: 0°C to 35°C (32°F to 95°F)
Non-operating: –20°C to 60°C (–4°F to 140°F)
Humidity Range
Operating: 10% to 80% (non-condensing)
Non-Operating:5% to 90% (non-condensing)
Altitude
Operating: 5,000 m (16,404 ft) max
Non-Operating: 12,191 m (40,000 ft) max
http://www.dell.com/en-us/shop/accessor ... u=210-AIEI
Look's like they redesigned the prototype. 60 Hz now instead of 120 Hz but at least they put DP 1.2 and HDMI 2.0 on it. Got it for $2,997 with military discount. Hopefully the input lag is low!
lexlazootin
Re: OLED 4K 30" 60 Hz - Dell UP3017Q
Post by lexlazootin » 13 Apr 2017, 06:31
Woo!
I think i want one.
Haste
Post by Haste » 13 Apr 2017, 08:38
60Hz :(
Monitor: Gigabyte M27Q X
Vega
Post by Vega » 13 Apr 2017, 13:34
Praise Jebus that was fast, my Dell OLED has already shipped! Arrives on Monday.
spacediver
Post by spacediver » 13 Apr 2017, 13:41
looking forward to hearing your experience with it :)
Post by Chief Blur Buster » 13 Apr 2017, 13:52
Keep us tuned on how it does -- it should have spetacular color and contrast ratios!
Beyond that:
It needs a Blur Reducing Mode!
OLEDs are very friendly to rolling-scan. I doubt DELL would enable that for 60Hz, but one can hope -- do let us know if you find a motion-blur-reducing mode for this OLED display.
Vega
Post by Vega » 16 Apr 2017, 19:28
Mark, in the user manual it states:
"Flicker Free On eliminates flickering by doubling the screen frame rate."
This one has me a bit worried. It is known that Samsung OLED displays in Laptops use PWM (240Hz) to prevent image retention. The wording of this isn't very clear. Doubling the screen frame rate? What do you think they are implying?
Manual: http://downloads.dell.com/manuals/all-p ... _en-us.pdf
Falkentyne
Post by Falkentyne » 16 Apr 2017, 19:52
Double strobing of course :)
Vega
Post by Vega » 17 Apr 2017, 01:16
Ya Falk I am quite confused. The frame rate is 60 Hz. PWM basically has nothing to do with frame-rate. It states it "eliminates" flicker by doubling the screen frame rate. So uh, it flickers at 120 Hz? I doubt Dell was stupid enough to set the PWM flicker that low. The PWM setting on Samsung laptop OLED panels is 240 Hz. I think maybe the Dell will do it at 480 Hz when set to "flicker free'?
What I would consider "eliminates flicker" would be no PWM at all. But what I think they mean is the frequency is high enough you can't actually "see" the flicker. I guess tomorrow I will know by adjusting the shutter speed on my camera.
knypol
Post by knypol » 17 Apr 2017, 07:49
Why do OLEDS even needs blur reduction feature if their response time is 0.1ms?
