Why do "Vertical Totals" help Blur Reduction? (ADVANCED FAQ)
Advanced display talk, display hackers, advanced game programmers, scientists, display researchers, display manufacturers, vision researchers. The masters on Blur Busters.
LordGurciullo
Re: Why do "Vertical Totals" help Blur Reduction? (ADVANCED
Post by LordGurciullo » 21 Mar 2019, 17:47
Do large vertical totals reduce input lag?
I'm at 182 now with my xl2546 and it feels cleaner and more crt like then 240 without.
Is this the way to go for lowest input lag?
Post by Chief Blur Buster » 23 Mar 2019, 02:08
Depends...
Indeed, Large Blanking Intervals (Large VTs) is indeed the fundamental principle of Quick Frame Transport (QFT).
(Incidentially, a variable refresh rate signal running at a low frame rate on a high-Hz monitor, is effectively a large blanking interval too -- given the variable-sized blanking interval nature of variable refresh rate signals)
For non-strobe lag, large VTs can behave as a defacto Quick Frame Transport (QFT) when used in conjunction with RTSS Scanline Sync to re-time frame presentation to beginning of visible refresh (end of BVI) rather than end of visible refresh (start of VBI)
However, some strobed monitors already has internal scan conversion for their strobed modes at lower Hz, e.g. partially pre-buffering a slow-scanning signal (e.g. 144Hz signal) for an accelerated scanout (faster than 1/144sec) -- to automatically internally create large blanking intervals without user intervention.
The buffering behaviour adds lag and can be bypassed via large vertical totals to pre-empt the prebuffering behaviour (e.g. deliver a 144Hz refresh cycle in 1/240sec via the use of a ToastyX Large Vertical Total trick).
Your frame transport acceleration factor will be (New Vertical Total) / (Original Vertical Total), so a VT1500 replacing VT1125 gives you a frame transport acceleration factor of 1.33x faster frame delivery. So, you really need a large vertical total raise to gain any input lag savings from a large VT.
This can trigger some monitors to skip its prebuffering step, with realtime sync between cable scanout and panel scanout (the art of sequential pixel delivery, one pixel row at a time, over the cable, and the LCD's electronics sequential refreshing behaviour), as seen in High Speed Videos of LCD Scanout
Now, a different way to reduce strobe lag is simply adjusting strobe phase, since the asymmetry between panel scanout versus global flash, creates a latency gradient along the vertical axis of the screen's surface.
Adjusting strobe phase to right below your screen crosshairs will generate the lowest strobed lag for your crosshairs. The lag is lowest right above the "strobe crosstalk bar" and highest right below the "strobe crosstalk bar".
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
