Windows 10 Bluriness
hello guys
i had windows 7 till last week.
in the weekend i installed windows 10 and now everything on my desktop is a bit blurry. i tryed diferent drivers, diferent dpi, but nothing works...
in games everything is fine but as soon as ii go to my desktop my eyes start crying Sad
please help me
please help me
Re: Windows 10 Bluriness
Are you sure you've set your desktop resolution correctly? What is your monitor's native resolution?
intheskyhaii
You'll be fine man. Just make sure your resolution settings are configured properly. Probably could just screenshot them.
i have the same config i had on windows 7, both resolution and VT...
Try using ToastyX to create the resolution (instead of NVIDIA) and see what happens.
Also, if you're using DPI scaling ("Scale and Layout" in "Change Display Settings"), change it to 100%
Make sure desktop size and position is set to no scaling in graphics card control panel and check cleartype as that probably reset itself or was never configured.
striker333
is output dynamic range set to full??
Can you post a screenshot?
In Windows 10, you can press Winkey+PrtScn and it will save a file in your Pictures folder.
hello guys, just got home, ill try what you guys sayd and post ss later. tnks all
ok, sorry but this was a busy weekend.
so, i have no scaling options active in windows or amd catalyst software.
i cant run toastyx, says my monitor is incompatible, but i mage to do a custom res in CRU.
ill leave a SS here, you can see the letlers in the word WINDOWS, on top, they are like if i dont use AA in games
tnks for your help.
http://imgur.com/a/UH9f9
i hope it shows in the SS, in my monitor is very clear
tnks for your help.
