Help with G-sync!!! [refresh rate problem; 680 SLI]
Posted: 23 Feb 2014, 21:30
Hello everyone,
I am new to the forum and site so let me start by saying hello and I'm glad to have found you! I recently purchased a modded ASUS VG248QE with G-sync. I have encountered many problems and since the tech is new there are not many outlets to get support available yet. I have yet to have a really spectacular experience with the monitor in games so far. I was hoping you guys with some hands on experience can help me. I'll start from the beginning to give as much info as possible. After I unboxed the monitor and got it all put together (Note: the G-sync was already installed by http://www.digitalstormonline.com/) I plugged it in and reinstalled my Nvidia drivers. After the driver was reinstalled it noticed the g-sync right away and configured itself. Seemed like it was going to be hassle free at that point. So I eagerly fired up the titanfall beta to try it out. Titanfall actually did pretty well with the monitor but there were still many instances where about 70% of my screen would go black for a few seconds randomly while playing. I know that Titanfall was locked to 60fps but my monitor wont do anything but 60fps in any game. When I go through the nvidia control panel to try to adjust the monitors refresh rate it will not cooperate. There also isn't an option for 144hz at all in the nvidia control panel or in windows display settings. When I do try to change it to say 120hz the screen will flash and the prompt will come up asking if I want to keep the changes but it will have changed it self back to 60. The only option that seems to work at all is 85hz and it only sort of works. The screen gets flashy and weird. I thought this might all be because I had my original 60hz monitor still plugged in as a second screen. I tried disabling that and unplugging it and there was no change. When the monitor is in "normal" mode everything runs fine and as it should but when g-sync kicks in when I start a game so far it has been significantly worse that just using my old monitor. Any and all suggestions/ideas would be appreciated. Thanks in advance
edit: idk if it matters but windows sees the monitor as generic PnP monitor.
Some of my PC specs:
2x MSI 680 lightning edition in sli
16gb ram
MSI mpower z77 mother board
900w PSU
16gb ram
900w PSU
