What should the test look like?
VinnyM
Hi,
Since the start of 2017, I've noticed that my games arent fluid anymore,
I would like to know what do I have to do to know what is the problem with my setup,
I used this test >> http://www.testufo.com/#test=framerates
But I dont know what It should look like, the 144fps is slightly better than 72fps,
And If I try to eyetrack the 144fps UFO my eye kind of hurt, and I cant see all the UFO details,
I have the G2460PF, i7 4790k, 970gtx, 16gb ram.
Please, someone help me
(btw, sorry about the shitty english)
Sparky
Re: What should the test look like?
The main difference would be that when your eye tracks the image, 144fps should have half as much motion blur as 72fps. If your monitor has a low persistence mode, the half framerate would have a doubled image. Anyway, that particular test is more of a demonstration of what different framerates look like than a test of your monitor. If you think your monitor is dropping frames, look at the frameskipping test.
VinnyM
I did the frameskipping test, and Its ok thoSparky wrote:The main difference would be that when your eye tracks the image, 144fps should have half as much motion blur as 72fps. If your monitor has a low persistence mode, the half framerate would have a doubled image. Anyway, that particular test is more of a demonstration of what different framerates look like than a test of your monitor. If you think your monitor is dropping frames, look at the frameskipping test.
Maybe my GPU is fcked?
Is 144fps TestUFO smooth or stuttery?
For a good modern 1ms TN 144Hz, the 144fps@144Hz should have about half motion blur of 72fps@72Hz.
If that's not happening for you, then something is wrong.
Certain older AOC G2460 firmwares were prone to frameskipping, which interferes with game fluidity, you should doublecheck. Newer AOC firmwares fixed this.
Check http://www.testufo.com/frameskipping
Make sure you use Chrome, close all windows and tabs, and make sure your browser is running stutterfree. Take a photo with your phone only when it says "READY", and post the photo here.
Ideally, it should look very approximately slightly less blurry than the 120Hz one below:
At 144Hz, you have about 6.9ms of persistence (1/144sec), so you will be slightly clearer than 120Hz but much blurrier than the 240Hz one.
VinnyM
OMG, that was what I was trying to find,Chief Blur Buster wrote:Is 144fps TestUFO smooth or stuttery?
Really thanks, helped alot!
You're welcome!VinnyM wrote:OMG, that was what I was trying to find,
Any frameskipping found in your monitor at www.testufo.com/frameskipping ?
Some very early versions of AOC firmwares skipped more than half of the squares at 144Hz.
VinnyM
Nops, 0 frameskipping, and the hz test, says that I got 143.89hz.Chief Blur Buster wrote:You're welcome!VinnyM wrote:OMG, that was what I was trying to find,
Any frameskipping found in your monitor at http://www.testufo.com/frameskipping ?
I dont know what to do, should I buy another GPU? Its a memory problem? When I watch streams of the game, It looks soo smooth, and I used to play smootly (v-sync off), and now, even with v-sync on, It doesnt look that smooth anymore
Did you try Fast Sync instead of VSYNC ON or VSYNC OFF?
Maybe the stutter mechanics of that is more similar to the YouTube videos you watch?
VinnyM
I've tried every sync optionChief Blur Buster wrote:Did you try Fast Sync instead of VSYNC ON or VSYNC OFF?
Do you know what can cause this? Maybe the memory? GPU? CPU? Life?
Did you have very good, smooth looking 144Hz before? Most of the "I had smooth 144Hz before but now I have stuttery 144Hz" problems tends to get fixed via a refresh software redo of the system.
Did you try:
-- Uninstall and reinstall graphics drivers? (don't just reinstall -- do a full uninstall first)
-- Reinstall the OS?
Also, accidental changes to detail levels can add to stuttering. If this is a possible cause, you may want to turn off all AA and use factory default graphics-detail settings, to get closer to what you used to have before at the same refresh rate. Many settings, including shader settings, shadow settings, AA settings, view-distance settings, can all add to increased stutters. You might have some kind of a framepacing issue. The same frame rate can be much more stuttery if it has very bad frame pacing.
Long-term, you might also want to consider a VRR monitor (G-SYNC or FreeSync) -- since variable refresh rate is much more forgiving of certain kinds of frame pacing issues (as long as gametime and frame visiblity time stays in sync, the pacing can be even random as long as it's synchronous between the game and refresh cycles -- and stutter is still hidden by the variable refresh rate nature)
Did you try:
