is DyAc having an inpact on input lag?
HOLECHIEN87
- lexlazootin
Re: is DyAc having an inpact on input lag?
DyAc doesn't add any buffering, so no.
dhaine
rtings.com has put some values on the XL2540, so while it's not the 2546 and official DyAc it should be quite similar :
Native Resolution: 3.7 ms
Non-Native Resolution: 3.7 ms
Native Resolution @ 60 Hz: 14.5 ms
Variable Refesh Rate: 3.6 ms
BFI: 5.5 ms (the hidden dyac of 2540)
http://www.rtings.com/monitor/reviews/b ... ng-monitor
- RealNC
All backlight strobing methods add a small amount of input lag, due to the image remaining black for a couple millisecond in order to give the LCD pixels time to transition. It can be anywhere between 1-3ms.HOLECHIEN87 wrote:is DyAc having an inpact on input lag?
This is needed in order to reduce crosstalk, which is the effect where the previous frame is partially visible together with the new frame when the pixels have not fully transitioned to the new colors yet. You can read more about it here:
https://www.blurbusters.com/faq/motion-blur-reduction
The added input lag is low enough to not matter, which is why many people answer "no" to the question of whether it adds input lag. Technically it does, but it's so small that it doesn't affect anything.
Traveler
Why is BenQ Zowie openly lying when they say on their website that DyAc+ won't add input lag, since it doesn't add any extra loading to the image processing to the monitor nor to the computer?RealNC wrote: ↑23 Oct 2017, 09:01All backlight strobing methods add a small amount of input lag, due to the image remaining black for a couple millisecond in order to give the LCD pixels time to transition. It can be anywhere between 1-3ms.HOLECHIEN87 wrote:is DyAc having an inpact on input lag?
The answer is more complex than a pure yes and no....
Not all pixels refresh at the same time, not all pixels have the same lag. See high speed videos at www.blurbusters.com/scanout
What this means is that at the time of the strobe flash, some pixels (e.g. typically the bottom screen edge during strobed VSYNC OFF) have less than 1ms lag relative to non-strobed. While other pixels have been refreshed a fairly long time ago and are thus lagged.
While average lag is up, there are some pixels with no lag-increase from strobing, and some pixels that have lag-increase from strobing.
An image from the old "Frequently Asked Questions – Troubleshooting" section of www.blurbusters.com/strobe-utility (old BenQ version):
If you want to change the position of your 0ms strobe lag, use Strobe Utility and move the crosstalk bar somewhere slightly underneath your crosshairs.
Traveler
Chief Blur Buster wrote: ↑12 Apr 2023, 00:57The answer is more complex than a pure yes and no....
