BenQ 24'' XL2411Z 144Hz Cable? problems
Posted: 27 Feb 2014, 20:32
Hi everyone! i am totaly new here so i dont know if i am doing the right thing, anyway, i will explain my problem.
I recently got a "BenQ 24'' XL2411Z 144Hz" knowing that my GPU could handle it, (Asus Radeon HD7970 DirectCUII TOP)
I know that there is that little switch on the card that makes a port dual dvi so i changed it (as i used a silly 60hz before
) and it should now work as a dual, i know i have it in the right dvi connection.
The problem is that whenever i change it to anything above 60hz (100hz, 120hz and 144hz) it works in windows at the desktop, but the second i start Loadout for example to test it, or even open firefox i get a smothering of the graphics and it says "use the dual dvi cable that you got in the box" and i am! why is this happening? am i missing something? i even installed the drivers for the screen from the disk (should it even be required? well i did)
what can i do to fix this? i am sorry that i am a total noob with anything 60hz< but i am a learning noob! i want to use it!
Thank you for your time!
