GSYNC vs CRT input lag?
baskinghobo
I was wondering which has less input lag? CRT of GSYNC? Also if CRT does have less input lag will the GSYNC input lag be noticable compared to the CRT input lag?
Haste
Re: GSYNC vs CRT input lag?
Hello baskinghobo and welcome to the forums.
Now, about G-Sync:
from BlurBuster: http://www.blurbusters.com/gsync/preview2/
As far as I know, every LCD monitors out there should have more imput lag than a CRT.baskinghobo wrote:I was wondering which has less input lag? CRT of GSYNC? Also if CRT does have less input lag will the GSYNC input lag be noticable compared to the CRT input lag?
Now, about G-Sync:
With VSYNC OFF averages of 72ms and 74ms, this is very similar to G-SYNC averages of 77ms and 74ms respectively. The variability of the averages appears to fall well below the noise floor of the high variability of Battlefield 4, so Blur Busters considers the differences in averages statistically insignificant. During game play, we were unable to feel the input lag difference between VSYNC OFF versus G-SYNC. This is good news; G-SYNC noticeably improved Battlefield 4 visual gameplay fluidity with no input lag compromise.
Monitor: Gigabyte M27Q X
- sharknice
I thought I saw Mark post the only added input lag from the VG248QE over a CRT is the pixel transition time.baskinghobo wrote:I was wondering which has less input lag? CRT of GSYNC? Also if CRT does have less input lag will the GSYNC input lag be noticable compared to the CRT input lag?
The latency differential between a modern (ASUS/BENQ) TN 120Hz LCD and a CRT is only about 1-2 milliseconds, when running in the best mode. This is mostly attributable to pixel transition time.baskinghobo wrote:I was wondering which has less input lag? CRT of GSYNC? Also if CRT does have less input lag will the GSYNC input lag be noticable compared to the CRT input lag?
prad.de confirms this too.
(From http://www.prad.de/new/monitore/test/20 ... sverhalten then translated using http://translate.google.com)
(That said, they did not test GSYNC).Latency
The latency is an important value for players, we determined as the sum of the signal delay time and half the middle picture change time. The VG248QE shows generally a very short signal delay: at 60 Hz, there are still 1.6 milliseconds at 120 Hz and then 1.2 at 144 Hz even only 0.7.
Also half the average image change time is 2.3 or 1.8 and 1.6 milliseconds by the bank extremely short, thus is fantastic overall latencies yield from 2.3 to 3.9 milliseconds. Even for the most demanding gamers, this is pretty much the ultimate.
Haste
How do you calculate that?Chief Blur Buster wrote:The latency differential between a modern (ASUS/BENQ) TN 120Hz LCD and a CRT is only about 1-2 milliseconds
The time between the signal going into the input, versus the pixels triggering a photodiode sensor connected to an oscilloscope.Haste wrote:How do you calculate that?Chief Blur Buster wrote:The latency differential between a modern (ASUS/BENQ) TN 120Hz LCD and a CRT is only about 1-2 milliseconds
Also, I forgot to also mention that there's a 1-2ms differential between VGA and DVI.
baskinghobo
Ok thanks. My monitor also supports displayport. Would that have even lower input lag than dvi or the same?Chief Blur Buster wrote:Also, I forgot to also mention that there's a 1-2ms differential between VGA and DVI.
- RealNC
Why is DP faster? Higher pixel clock? Does that mean that we can lower input lag over DVI by tweaking the timings? (Reduced vs standard CVT, for example.)
ENiKS
DP limit is 4K@60Hz, which means it should be able to do 1920x1080@240Hz, therefore taking 4.2ms to upload a FullHD frame. Dual Link DVI limit is 1920x1080@144Hz, taking 7.9ms.
I'm not sure if the transmit speed is fixed or changing according to monitor refresh rate. I will try to measure actual values.
