24" 144-240hz monitor suggestions
Posted: 29 Dec 2017, 12:15
by hauskamieS
I am looking for a 24 inch competitive gaming monitor. For now I've been looking at Acer Z271, Acer XB252Q, Acer XB241H and ASUS PG248Q. My current monitor is BenQ XL2411Z and I've been fairly happy with it, but it's time to try out a GSYNC monitor.
Gaming is by far the most important thing for me, I will pretty much only game on the PC that I will buy the monitor for. There is a sale for XB252Q atm, making it almost as cheap as the XB241H. Z271 and PG248Q are pretty expensive where I live.
Which of these would be a good upgrade, and where can I expect to see a difference if I upgrade. Can I expect a better picture quality/colors from a more premium TN such as the XB241H and PG248Q compared to the BenQ XL2411Z?
PC specs: i7-7700K & GTX 1070 Ti
Re: 24" 144-240hz monitor suggestions
Posted: 29 Dec 2017, 21:19
by lexlazootin
Anything is better then the XL2411Z, Most of the G-Sync monitors are going to perform pretty identical. If you can get the 240hz get that but if you can find a Acer 240hz with G-Sync or any other 240hz with G-Sync for cheaper get that, because like i said, it's going to be identical performance wise.
