Desk Setup Thread! [POST YOUR PICS]
1000WATT
Re: Desk Setup Thread! [POST YOUR PICS]
Post by 1000WATT » 03 Jun 2020, 06:22
Yes, the temperature delta does not change much. -2 -3 degrees. But why then a small radiator? For the sake of silence?
Wacu
Post by Wacu » 22 Jul 2020, 12:34
Pretty new here but since i just changed my monitor arms and cleaned up i thought its share worthy.
https://imgur.com/a/h7pcJJR - some details
ropeadope
Post by ropeadope » 13 Sep 2020, 04:11
Great setup, Wacu! :)
alapsu
Post by alapsu » 06 Nov 2020, 09:32
Wacu wrote:
22 Jul 2020, 12:34
Necroing to ask about the stand for your middle monitor. It looks like that pole is coming out of a grommet you drilled in the desk, and then it also looks like you cut a circular hole in the deskpad of the same diameter as the pole. Is that correct?
If so, how did you cut such a clean hole in the desk pad? I tried something similar on an old mousepad just to see if it would work and it just ended up as a frayed mess that I threw away.
StuckIn2003
Post by StuckIn2003 » 13 Jan 2021, 12:47
New l-shaped standing desk, keyboard, and mouse. Very happy with everything thus far:
https://imgur.com/a/p6Cgz6m
Post by Chief Blur Buster » 16 Jan 2021, 19:51
Thanks for posting pictures!
Keep 'em coming, for anybody who hasn't posted a photo of their rigs.
sharknice
Post by sharknice » 18 Jan 2021, 19:47
I use an LGCX 48" oled now. 4k@120hz with gsync is amazing.
I played some Battlefront 2 last night as a sniper and the extra resolution makes it a lot easier to get extremely long range snipes.
fins
Post by fins » 18 Jan 2021, 23:27
IMG_0216 copy.jpg (6.91 MiB) Viewed 36263 times
My monitors are Lenovo Legion Y25-25 & Dell U3415W.
I just upgrade my motherboard and CPU to ASRock B550M Pro4 and AMD Ryzen 5 5600x. The rest is quite old: 24GB of 2667MHz RAM, AMD RX580 8GB. I have 2 SSD disks: one for Windows, the other for "Ryzenosh" (for work), plus an NVMe drive for "clips" in gaming. Instead of the other NVMe drive, I have an adaptor with an Apple Airport card on it for Wi-Fi/Bluetooth.
PiCKiN
Post by PiCKiN » 24 Jan 2021, 15:31
sharknice wrote:
18 Jan 2021, 19:47
Oh man that is crazy. You don't get motion sickness or dizzy being that close to a big monitor?
sharknice
Post by sharknice » 25 Jan 2021, 21:32
Nope, it just feels more immersive. Games with higher fov work the best. The immersion actually makes it easier to focus and aim better, and the extra detail 4k resolution provides helps a lot too. It's kind of like having the extra accuracy of being scoped in on a target but without losing your peripheral awareness.
And since it's the same dpi as 24" 1080p screens it works out great for productivity, it's just like using 4 of them.
