Help me to chose gaming monitor [please]
Posted: 03 Mar 2014, 17:23
by RulezRus
First, sorry for my bad english. It's not my native languge.
I'm going to buy a gaming monitor, but still can not decide which to buy.
My PC Specs: i5-4670k + GTX MSI 770 2GB
I usually play Single Player Games and the online games like: Dota 2, Battlefield 4, CS:GO, World of Tanks.
Here's my proposed monitors:
Benq XL2411T
Asus VX239H
Asus VG248QE
Benq RL2455HM
Please help me to choose good monitor for comfort gaming and not so expensive like EIZO. I'm living in Russla and for buying ips 120hz monitor from Korea is expensive also.
Sorry for my bad english again 8-)
Re: Help me to chose gaming monitor [please]
Posted: 03 Mar 2014, 20:57
by srsbsns
Benq XL2411Z if at all possible. The Eizo is the only other gaming monitor I would consider. If you pick the XL2411T that would also be a good choice. Make sure to get something to calibrate with and you will be very happy.
The motion clarity on the BenQ is second to none.
Posted: 04 Mar 2014, 05:29
by Haste
Take whichever is cheaper between Benq XL2411T and Asus VG248QE.
(And once you get the monitor, check here how to enable and configure the lightboost hack.)
This will help you mostly for CS:GO
And welcome to the forums :)
Posted: 04 Mar 2014, 06:02
by vhn
Wouldn't the BenQ 2411Z be a better recommendation or am I missing something?
With the fixed firmware and the utility coming soon it sounds like it has better strobing and better colors than the previous generation of lightboost-strobed monitors at around the same price.
I'm personally waiting a bit for the g-sync monitors to release since I would prefer a strobed monitor for games like CSGO where I can keep a constant framerate of 144 fps and then g-sync for games like BF4 where it will fluctuate below 70 fps.
Only problem is, I'm not sure how expensive the g-sync monitors are going to be. I read this interview with Nvidia’s Director of Technical Marketing for GeForce which points towards expensive g-sync monitors to begin with:
"As for cost, in so many words Petersen suggested the monitor makers see G-Sync as a nice opportunity to make some margin and that means opening high with pricing and adjusting down if the market won’t swallow it. He also said the added cost of G-Sync for a monitor that’s had its scaler board swapped out for a G-Sync board (rather than adding G-Sync and keeping the existing board) is around $50. That sounds like a pretty big addition to the bill of materials to me and that’s a shame because G-Sync is a seriously nice technology."
Posted: 04 Mar 2014, 07:16
by Haste
vhn wrote:Wouldn't the BenQ 2411Z be a better recommendation or am I missing something?
It wasn't in the OP's list.
If you can get it then yes. Take the Z in place of the T. And be sure to download the "Blur Busters Strobe Utility For BENQ Z-Series Monitors"
vhn wrote:I'm personally waiting a bit for the g-sync monitors to release since I would prefer a strobed monitor for games like CSGO where I can keep a constant framerate of 144 fps and then g-sync for games like BF4 where it will fluctuate below 70 fps.
That's a good plan. I'm waiting for gsync displays for the same reasons.
One thing you should be aware of: Unfortunately, unlike the BenQ Z series solution, the g-sync monitors can't strobe at 144Hz. Only up to 120Hz. I find it pretty disappointing in that regard.
vhn wrote:Only problem is, I'm not sure how expensive the g-sync monitors are going to be. I read this interview with Nvidia’s Director of Technical Marketing for GeForce which points towards expensive g-sync monitors to begin with:
Well the first official gsync monitor that will be available (should be soon) will be around 800 Dollars.
Keep in mind it's an 8bit TN (instead of a 6bit). It's 27 inches and it's WQHD (2560 x 1440) and has the "Republic of Gamers" branding. Given all that, it doesn't seem like gsync had a big impact on the price position of that product.
Posted: 04 Mar 2014, 12:01
by RulezRus
Thanks to all for your response.
Its not available in my country. :cry:
I will buy benq 2411T first, then would be waiting for asus rog g-sync monitor.
Posted: 04 Mar 2014, 12:44
by RulezRus
1 more question :roll:
Will it be comfortable to play in such game like Grid 2, Metro 2033, Far Cry 3 and some new singleplayer games?
Posted: 04 Mar 2014, 14:15
by Haste
RulezRus wrote:1 more question :roll:
These monitors will shine more in multiplayer but they will provide a great experience in those titles as well.
For the case of Metro 2033, the GTX 770 will most likely not provide enough fps for lightboost/benq motion blur reduction. So for this game leave the strobbing off. Strobbing works best when the fps your Graphic card is providing = the refresh rate of the monitor.
For example 120fps vsync + 120Hz monitor stobbed => This will give you the best experience.
Hope that helps.
Posted: 04 Mar 2014, 14:18
I should point out that BENQ Blur Reduction works as low as 75Hz. (or 60Hz with the new Blur Busters Strobe Utility). 75Hz or 85Hz will provide the best compromise. With the new adjustable persistence options in Blur Busters Strobe Utility, it's now possible to get less motion blur during 75fps@75Hz than at 120fps@120Hz.
That said, that's only if you're lucky enough to have a supported Z-Series monitors since not all of them are supported.
